Clearing part level appearance
NachoShaw
Advisor Advisor
Message 1 of 1
NachoShaw
Hey
i am working with a model that is imported from a step file and it has a range or colors to each part. i am assigning a material at assembly level but need to remove the appearance override at part level. Can this be done without actually opening each part individually invisible? To manually remove the appearance, the solid needs to be selected and then the remove overrride is present in the material dropdown but id like to do this by code
Nacho
Automation & Design Engineer
Inventor automation Programmer (C#, VB.Net / iLogic)
Furniture, Sheet Metal, Structural, Metal fab, Tradeshow, Fabrication, CNC
Replies (0)
