Comparing text strings and not getting correct answers
SteveK88
SteveK88
Hi,  I am comparing Text strings and not getting the list of results I want.  I am using 'contains' and am looking to find all the text strings that are found in "B-ananas" using a list. The expected result should contain 4 answers because of 'contains' but I only get one result   Please take a look.
here is the code....
Dim oSTr As String
oSTr = "B-ananas"
'FilterName = "na"
'FilterName = "B-"
	'Add Select Cases for Filter Terms
	Dim FilterValue As New List(Of String) ' List starts at 0
		FilterValue.Add("PartName1")
		FilterValue.Add("B-")
		FilterValue.Add("xB-")
		FilterValue.Add("sss B- xx")
		FilterValue.Add("sss b- xx")
Dim FilterName As String
For Each FilterName In FilterValue
			If oSTr.Contains(FilterName) Then
			MsgBox("oStr = " & oSTr & ", FilterName = " & FilterName)
		End If
Next
SteveK88
Forget it.  bad data.  works fine.
Dim oSTr As String
oSTr = "B-"
			'If oSTr.Contains(FilterName) Then
				If FilterName.Contains(oSTr) Then
		End If
Next
