Comparing parameter value before and after
James115
Message 1 of 8
James115
Simplified example here, but I have a Form to allow users to change the value of User Parameter X. The form shows read-only User Parameter Y and Z. The value of Y is calculated as 5 * Parameter X. In case the user enters a value for X and clicks Apply and that leads to Y being higher than Z, I would like to revert the value that the user entered to the previous value for X (so the last value before Y exceeds Z).
What I tried is reading the values with i.e.:
iLogicForm.Show("Test").GetField("X").Value
or .Forms
But that gives errors like:
'Values' is not a member of 'Autodesk.iLogic.Interfaces.FormReturnValue'
"It may be inaccesible due to its protection level"
Another way would be fine too, this is just what I thought of, thanks in advance!
Replies (7)
Message 2 of 8
Preston_Reed
If i understand, if the value entered then results in other values that exceed limits then you want to revert the values back to what they were before.
I would just use the user parameters.  Run what you have so far in terms of the math and update the model, then in the next routine check the value of the user parameter and if its not ok then replace the parameters.  Something like:
Sub main
	Math
	Check
	RuleParametersOutput()
	iLogicVb.DocumentUpdate()
End Sub
Sub Math
	' Do your math here ( you can just use another user parameter here too to keep track of the result)
	math = Result
	' Save the previous entry if you want to go back to it
	' Can use another user parameter
	ParameterX = OriginalValue
	' Update model
End Sub
Sub Check
	If Result > Limit Then
		ParameterOriginal = ParameterX
	End If
End Sub
Message 3 of 8
James115
@Preston_Reed  Thanks for helping, not sure if the solution below is what you meant, but I would prefer not to create too many User Parameters. I'm new to iLogic/coding. Some questions:
  1. In the example of Y = 5 * X, would this line be used to define the actual value of Y? Or to define a test result?
    ' Generic
    math
    = Result
    ' Filled in example
    Y = 5 * ParameterX
  2. I'm stuck on how to capture the "OriginalValue" when the user changes X, since Y will change only after that.
  3. I could make User Parameter "TestX" and have users enter that value in the form:
    Result = TestX * 5
    	If Result > Z Then
    		TestX = X
    		Else
    			X = TestX
    	End If
          But since Y is not only dependent on X, but also on A, B etc. I would have double the parameters (TestX, TestA, TestB)
So I prefer using Dim instead of User Parameters to capture the before value for instance that would be okay.
Message 4 of 8
Preston_Reed
Hey @James115 , i made some changes and this should do what your looking for.
Sub main
	Rule
End Sub
Sub Rule
''' Math
	' Declare variables
	Dim InputX As Double
	Dim Y As Double
	Dim Z As Double
	Dim OriginalX As Double
	Dim OriginalY As Double
	Dim OriginalZ As Double
	' Save initial values
	' You are going to need a Parameter X,Y & Z in order to use the form
	' Do this first to caputer the values of the parameter, aka the previous values
	OriginalX = ParameterX
	OriginalY = ParameterY
	OriginalZ = ParameterZ
	' Do math here
	Y = 5 * InputX
	Z = 2 * InputX
	' Apply values to the parameters
	Parameter("ParameterX") = InputX
	Parameter("ParameterY") = Y
	Parameter("ParameterZ") = Z
	' Update model
''' Check
	If Y > Z Then
		Parameter("ParameterX") = OriginalX
		Parameter("ParameterY") = OriginalY
		Parameter("ParameterZ") = OriginalZ
	Else
		' Do nothing
	End If
End Sub
No worries about just starting iLogic, I am still pretty new to it but this forum and the Autodesk University stuff is where i learned everything, they are great resources
Message 5 of 8
Curtis_Waguespack
Hi @James115
I don't think there is really a very good way to do this with iLogic other than:
  • storing the previous value in a user parameter or iproperty, at the end of the rule so we have it next time around
  • or deconstructing the math to reset the value
Deconstructing the math:
So for instance if Y = X * 5 then we would use Parameter Y / 5 to get the previous X value as shown in this example.
See 2024 example attached.
InputX = ParameterX
'calc new value
Y = 5 * InputX
If Y > Parameter("ParameterZ") Then
	'calc previous value
	previousX = Parameter("ParameterY") / 5
	MsgBox("Y > Z" & ", setting X back to " & previousX _
	& vbLf & InputX & " x 5" & " = " & Y, , "iLogic")
	'set back to previous value
	Parameter("ParameterX") = previousX
Else
End If
I hope this helps.
Curtis
Message 6 of 8
Curtis_Waguespack
@Preston_Reed ,  Just a quick FYI... as written the example you posted doesn't ever set InputX
Message 7 of 8
Preston_Reed
Oops, you are right, thanks for catching that!
Message 8 of 8
James115
@Preston_Reed thanks it works!
@Curtis_Waguespack I tried deconstructing it, but for my case it'll be hard to adapt the code in the future so decided not to. For simple math it seems like a good solution too.
