CommandManager.ActiveCommand is not set with my command
HideoYamada
Advisor Advisor
Message 1 of 21
HideoYamada
Please see two pictures below.
Built In CommandBuilt In CommandMy CommandMy Command
When I execute a built in command, the internal name of the command will be set to ActiveCommand.
But with executing my command that is created by C#, the name is not set.
I tried to get a name when OnExecute was just called.
public override void ControlEvents_OnExecute(NameValueMap options)
    System.Diagnostics.Debug.WriteLine("ActiveCommand : " + InventorApplication.CommandManager.ActiveCommand);
This caused...
ActiveCommand : AppSelectNorthwestArrowCmd
How can I set my command name to CommandManager.ActiveCommand?
Best regards,
Freeradical
 Hideo Yamada
Freeradical
 Hideo Yamada
https://www.freeradical.jp
Accepted solutions (4)
Replies (20)
Message 2 of 21
chandra.shekar.g
Autodesk Support
Autodesk Support
@HideoYamada,
Hoping that suggestions in the below blog link may be helpful.
https://modthemachine.typepad.com/my_weblog/2009/03/running-commands-using-the-api.html
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
Message 3 of 21
HideoYamada
Hello chandra,
Thank you for your reply.
Unfortunately that was not the answer for me.
I've written a simple test code.
public class StandardAddInServer : Inventor.ApplicationAddInServer
    private Inventor.Application m_inventorApplication;
    ButtonDefinition definition;
    public StandardAddInServer() {}
    public void Activate(Inventor.ApplicationAddInSite addInSiteObject, bool firstTime)
        m_inventorApplication = addInSiteObject.Application;
        definition = m_inventorApplication.CommandManager.ControlDefinitions.AddButtonDefinition("ActiveCommandTest", "ActiveCommandTest", CommandTypesEnum.kShapeEditCmdType, "MyClientID");
        definition.OnExecute += Definition_OnExecute;
    private void Definition_OnExecute(NameValueMap Context)
        MessageBox.Show("ActiveCommand : " + m_inventorApplication.CommandManager.ActiveCommand);
    public void Deactivate()
        definition.OnExecute -= Definition_OnExecute;
        m_inventorApplication = null;
        GC.Collect();
        GC.WaitForPendingFinalizers();
    public void ExecuteCommand(int commandID) {}
    public object Automation
        get { return null; }
The MessageBox always says 'AppSelectNorthwestArrowCmd'.
It was tested with Inventor 2019 and 2020.
Does anyone know what happens (or not)?
Best regards,
Freeradica
 Hideo Yamada
Freeradical
 Hideo Yamada
Message 4 of 21
chandra.shekar.g
Autodesk Support
Autodesk Support
@HideoYamada,
Can you please provide non confidential code and reproducible steps to test the behavior?
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Message 5 of 21
HideoYamada
Hello Chandra,
I attached the project archive of the test code.
Open a part document and execute this command, and then you can see the dialog of ActiveCommand.
The code and results are the same as described in my last post.
Best Regards,
Freeradical
 Hideo Yamada
Freeradical
 Hideo Yamada
Message 6 of 21
chandra.shekar.g
Autodesk Support
Autodesk Support
@HideoYamada,
On successful execution of source code, where is "ActiveCommandTest" button created?
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Message 7 of 21
HideoYamada
Hello Chandra,
No button will be created.
Please assign "ActiveCommandTest" to a key.
It's better to open a document file before doing the test, because sometime invoking command by the key is ignored when it is in the ZeroDoc environment.
Best regards,
Freeradical
 Hideo Yamada
Freeradical
 Hideo Yamada
Message 8 of 21
jjstr8
If you're in the OnExecute handler for your command, you already know what the command is.  What do you need ActiveCommand for?  Just for reference, Inventor reports the ActiveCommand as the default command for my custom commands as well.
Message 9 of 21
HideoYamada
Hello jjstr8,
I want to know other command is already running or not when my command is executed.
Build-in commands sets their names to ActiveCommand and I can do proper processing
(e.g. cancel this execution, terminate the running command)
But my commands cannot know other command I made is running or not.
This is the problem.
Freeradical
 Hideo Yamada
Freeradical
 Hideo Yamada
Message 10 of 21
NachoShaw
What is the window you show that displays the running commands? Is that an inventor tool?
Nacho
Automation & Design Engineer
Inventor automation Programmer (C#, VB.Net / iLogic)
Furniture, Sheet Metal, Structural, Metal fab, Tradeshow, Fabrication, CNC
Message 11 of 21
HideoYamada
Hello NachoUK,
Only I want to do is knowing another command is running or not.
Please see below
If another standard Inventor command is executed in this situation, already running command (Extrude) will be canceled and then new command will be executed.
When my command is executed in this situation, my command runs with another command (Extrude) running. (and this will make Inventor crash)
So I want know command is already running or not.
It is said same thing when my command is running first. I think that my commands must tell they are running or not via CommandManager.ActiveCommand.
Or, is there a way to execute command as modal?
Freeradical
 Hideo Yamada
Freeradical
 Hideo Yamada
Message 12 of 21
jjstr8
Hideo,
As best I can tell, only built-in commands report through ActiveCommand.  In your last post you asked about running a custom command as modal.  In your OnExecute method, use ShowDialog() instead of Show().  If there are cases that this doesn't work for you, I've tested another way for custom commands in a single addin to close each other.  Let me know if you want the details.
Jeremy
Message 13 of 21
HideoYamada
Hello jjstr8,
Ah, It's a bad news for me.
Some of my commands have no Window forms. (but FileDialog and UserInteractionEvents)
I can tell to my commands that the others I made are running or not, but still my commands can't know about the add-in which is made by someone else.
I am publishing my commands at App Store. I want to tell to someone's add-in at least about state of my commands.
(To avoid someone's add-in making Inventor crash while my commands are running.)
But it seems that there is no way...
Freeradical
 Hideo Yamada
Message 14 of 21
BrianEkins
The reason you're not seeing your command as the active command is that you haven't created a command.  You've created a button definition, added a control to the ribbon, and are listening for the OnExecute event.  This doesn't result in a command being run, but only in notifying you that a button was clicked.  You should see that whatever the active command is when you click the button, remains active.
To create a real command you need to do what you're doing but in the OnExecute event you need to create an InteractionEvents object and start it.  This is what actually starts your custom command.  Doing this will terminate the currently running command and you'll now have primary access to all of the user events.  In addition, your command will be returned as the active command.
Brian Ekins
Inventor and Fusion 360 API Expert
Website/Blog: https://EkinsSolutions.com
Message 15 of 21
HideoYamada
Hello BrianEkins,
Thank you for replying.
(omission)
Please see the first post on this thread.
When an InteractionEvents starts then pre-executed command will be terminated as you said.
However, ActiveCommand is set to 'InteractionEvents' (not my command name).
And executing the standard Derived Part command cause opening file dialog and closing pre-exexuted command.
(There is no InteractionEvents!)
Is this a lack of API functionality?
Now I think so.
Best regards,
Freeradical
 Hideo Yamada
Freeradical
 Hideo Yamada
Message 16 of 21
jjstr8
Hideo,
It looks like you need to set the command name through the InteractionEvents object you created.  I'm not sure where you're doing this in your code, but it can be done in your command's class constructor.
public partial class MyCommandForm : Form
     private Inventor.Application inventorApp;
     private Inventor.InteractionEvents interactionEvents;
     public MyCommandForm(Inventor.Application app)
           inventorApp = app;
           interactionEvents = inventorApp.CommandManager.CreateInterationEvents();
           interactionEvents.Name = "MyCustomCommand";
           interactionEvents.Start();
     private void MyCommandForm_FormClosing(object sender, FormClosingEventArgs e)
            interactionEvents.Stop();
This is just an example.  I don't know if it fits your needs exactly.  Any "start" of another interaction events object will overwrite ActiveCommand (either with the .Name of the new one or "InteractionEvents" if .Name == "").
Jeremy
Message 17 of 21
jjstr8
I think what NachoUK is asking is what is the window in your original post with the green title bar?
Message 18 of 21
HideoYamada
Hello jjstr8,
ActiveCommand could be set as you said. Thank you!
Freeradical
 Hideo Yamada
Freeradical
 Hideo Yamada
Message 19 of 21
HideoYamada
Thank you for the advice, jjstr8.
The window with the green title bar is the watch window of VBA.
(I should have run the English version, sorry > all)
Freeradical
 Hideo Yamada
Message 20 of 21
HideoYamada
Thanks a lot all of you!! I got a solution.
<<Conclusions>>
(1) CommandManager.ActiveCommand can be changed by starting InteractionEvents.
(2) InteractionEvents.Start() will stop the command already executed.
(3) Every command that will make a document dirty needs to start InteractionEvents, even if the command doesn't require user interaction.
(3) is important. Because a change of the document when another command is running sometime cause a crash of the command or Inventor.
Freeradical
 Hideo Yamada
Freeradical
 Hideo Yamada
