- Mute
- Permalink
- Report
A forum search has revealed that the Surface feature tools are not currently supported in the API, and as the sheet metal features are failing where the surface features are not, I appear to be forced down the path of using the Command Manager to attempt to automate a process, and the CM is a new beast to me. (My Autodesk rep has already looked over the sheet metal failures and has pointed me to surfaces, please avoid the desire to try and solve the sheet metal issues I haven't provided details on).
I'm currently at a loss on how to make selections via the CM and was hoping that someone might provide some example code, I should be able to figure out how to apply it to my routines from there.
The command requires that I pick the 2d sketch to define the Cutting Tool (a pre-select failed to work here), then select the faces to remove, and then finally to accept the choices to complete the command.
I do know the 3d points for any of the edges I wish to choose and would be a snap to just pick a UCS point to select an item; but again here I need a crash course on how to make these selections and advance the command progression.
Anyone able to provide some pointers, and preferably an example I could adapt?
