combobox select action
Message 1 of 9
I have added a combobox named  m_pipeworkComboxDefinition to my custom panel in my addin,
Can someone help me with how to trigger a sub when it's value is changed?
Thanks in advance.
Replies (8)
Message 2 of 9
Owner2229
Hi, I suppose you're working in VB.Net as you haven't stated else, so:
Somewhere in your form initialization (or in StandardAddInServer.vb > 'Activate' for the Ribbon panel) paste this line:
AddHandler Me.m_pipeworkComboxDefinition.TextChanged, AddressOf Me.MyComboChange
Then you can add the referenced Sub:
Sub MyComboChange
    MsgBox("Tada, it works!")
End Sub
Consider using "Accept as Solution" / "Kudos" if you find this helpful.
Mike
"Always code as if the guy who ends up maintaining your code will be a violent psychopath who knows where you live." - John F. Woods
Message 3 of 9
Thanks for the quick reply.
I tried adding your code as suggested but no luck.
I suppose I should've said this at the start:
This is the code (taken from the simpleaddin sample) that am using to generate my combobox:
#Region "Data Members"
        'combo-boxes
        Private m_pipeworkComboxDefinition As ComboBoxDefinition
#End Region
Public Sub Activate(ByVal addInSiteObject As Inventor.ApplicationAddInSite, ByVal firstTime As Boolean) Implements Inventor.ApplicationAddInServer.Activate
                'create the comboboxes
                m_pipeworkComboxDefinition = InvApp.CommandManager.ControlDefinitions.AddComboBoxDefinition _
                 ("Pipework", "Autodesk:MyAssemblyTools:PipeMatCboBox", CommandTypesEnum.kShapeEditCmdType, 200, addInCLSIDString, _
                  "Select Which Piping Material To Use", "Piping Material")
                'add some initial items to the comboboxes
                m_pipeworkComboxDefinition.AddItem("Carbon Steel", 0)
                m_pipeworkComboxDefinition.AddItem("Low Temp Carbon Steel", 1)
                m_pipeworkComboxDefinition.AddItem("Stainless Steel", 2)
       ' add the combo boxes to the Tube and pipe tab panel panel
                        Dim PipeworkCmdCboBoxCmdCtrl As CommandControl
                        PipeworkCmdCboBoxCmdCtrl = parttubeandpipeRibbonPanelCtrls.AddComboBox(m_pipeworkComboxDefinition, "", False)
end sub
When I added in your code in it highlighted the .TextChanged part with the error:
'TextChanged' is not a member of 'Inventor.ComboboxDefinition'
Message 4 of 9
Jef_E
EDIT: bad post..
Please kudo if this post was helpfull
Please accept as solution if your problem was solved
Inventor 2014 SP2
Message 5 of 9
I don't follow,
My addin is a combobox that I've added to a new ribbon panel I've created.
I declared the combobox using the simpleaddin sample as a roadmap.
What other methods are there to declare a combobox?
Ta,
Message 6 of 9
Jef_E
Sorry, I should have read your code better.. I thought it was a combo-box on a windows form.. Still little bit sleepy? 😄
Inventor 2014 SP2
Message 7 of 9
Owner2229
Alright, since it is Inventor's ComboBoxDefinition, you can try this:
AddHandler Me.m_pipeworkComboxDefinition.OnSelect, AddressOf Me.MyComboChange
Place it at the end of your Activate Sub.
... and don't forget to add the "MyComboChange" Sub again.
Mike
Message 8 of 9
Fantastic!!
Working perfectly now.
many thanks.
Message 9 of 9
Owner2229
You're welcomed Smiley Happy
Mike
