Hi All,
I am new to ilogic. I would like to use part color based on different material and processes, I am using manual appearance change now. Is it possible to automate the processes?
The processes flow will be.
Open part > Select part > Click the I logic button Change color (Run the script)
Open and select part or surface will be manual.
Is it possible to add RGB in I logic instead of color name like read, green ec..?
Thanks in Advance,
Justin
