Color change using i logic
justin.johnsonQLTK2
justin.johnsonQLTK2
Hi All,
I am new to ilogic. I would like to use part color based on different material and processes, I am using manual appearance change now. Is it possible to automate the processes?
The processes flow will be.
Open part > Select part > Click the I logic button Change color (Run the script)
Open and select part or surface will be manual.
Is it possible to add RGB in I logic instead of color name like read, green ec..?
Thanks in Advance,
Justin
Stakin
JMGunnar
JelteDeJong
If you want a bit more information out of the colouring of your parts (then the rule that Clint wrote) have a look at this post: "Set different colour for each component of Assembly based on the PN." Here the colours are based on the part number.
Jelte de Jong
Blog: hjalte.nl - github.com
justin.johnsonQLTK2
Thanks all for your help..
justin.johnsonQLTK2
Dim oDoc As PartDocument = ThisDoc.Document
Dim oRenderStyles As RenderStyles = oDoc.RenderStyles
Dim oName As String = "ALUMINIUM_MACHINING"
Dim styleExists As Boolean = False
Dim myStyle As RenderStyle
For Each oRenderStyle As RenderStyle In oRenderStyles
 If oRenderStyle.Name = oName
  styleExists = True
  myStyle = oRenderStyle
  Exit For
 End If
Next
If Not styleExists
 myStyle = oRenderStyles.Add(oName)
 myStyle.SetAmbientColor(255, 190, 190)
 myStyle.SetDiffuseColor(255, 190, 190)
End If
For Each oSurfBod As SurfaceBody In oDoc.ComponentDefinition.SurfaceBodies
 For Each oFace As Face In oSurfBod.Faces
  oFace.SetRenderStyle(37123, myStyle)
 Next
Next
I found this helpful
