collision - tapped holes and srews
GeorgK
Advisor Advisor
GeorgK
Hello together,
I write a program to find all collisions in an assembly. This works very well. The problem is to exclude the screws which are in tapped holes.
Is there any function to solve the problem?
Georg
ekinsb
There's nothing built into Inventor or the API to help with this.  You have to know somehow which parts are screws and either not include them in the interference analysis or leave them in but ignore their interference in the result.
Brian Ekins
Mod the Machine blog
GeorgK
Hello Brian,
do you have a sample code for this? But I could not exclude screws. Sometimes there is an fault in the design and the screw is in the middle of a part.
Georg
dg2405
Hello Georg,
i've made some Code like this:
its not complete. When i have time, i will add some filters for the thread collisions.
Sub Kollision_Prüfen_Gesamt()
    'On Error Resume Next
    'Auf Bg zugreifen
    Dim oApp As Inventor.Application
    Set oApp = ThisApplication
    Dim oAsmDoc As AssemblyDocument
    Set oAsmDoc = ThisApplication.ActiveDocument
    Dim oAsmCompDef As AssemblyComponentDefinition
    Set oAsmCompDef = oAsmDoc.ComponentDefinition
    Call oAsmDoc.BrowserPanes.ActivePane.TopNode.DoSelect
    'Pos. 1 aktivieren
    Call oAsmCompDef.RepresentationsManager.PositionalRepresentations.Item(1).Activate
    'Set erstellen
    Dim oAllOccurrences As ObjectCollection
    Set oAllOccurrences = ThisApplication.TransientObjects.CreateObjectCollection
    'Nicht sichtbare entfernen
    Dim oOcc As ComponentOccurrence
    For Each oOcc In oAsmCompDef.Occurrences
        If oOcc.Visible = True Then
            Call oAllOccurrences.Add(oOcc)
        End If
    Next
    'Kollisionen berechnen
    Dim oResults As InterferenceResults
    Set oResults = oAsmCompDef.AnalyzeInterference(oAllOccurrences)
    'Bodys erstellen
    Dim oResult As InterferenceResult
    Dim oTotalBodyRed As SurfaceBody
    Dim oTotalBodyGreen As SurfaceBody
    Dim oTotalBodyThreadLength As SurfaceBody
    For Each oResult In oResults
        Dim oHelpBody As SurfaceBody
        Set oHelpBody = Nothing
        Dim ThreadVorhandenLarge As Boolean
        Dim ThreadVorhandenSmall As Boolean
        ThreadVorhandenLarge = False
        ThreadVorhandenSmall = False
        Dim ThreadOffen As Boolean
        ThreadOffen = True
        Dim oCylinderFaceLarge As Face
        Dim oCylinderFaceSmall As Face
        Set oCylinderFaceLarge = Nothing
        Set oCylinderFaceSmall = Nothing
        Dim oCylinderLarge As Cylinder
        Dim oCylinderSmall As Cylinder
        Set oCylinderLarge = Nothing
        Set oCylinderSmall = Nothing
        'Bohrungsgrößen:
        Dim aussen_Arr
        Dim kern_Arr
        'Gewinde DIN M2.5-M30
        aussen_Arr = Array(2.5, 3, 4, 5, 6, 8, 10, 12, 16, 20, 24, 30, 5, 6)
        kern_Arr = Array(2.013, 2.459, 3.242, 4.134, 4.917, 6.647, 8.376, 10.106, 13.835, 17.294, 20.752, 26.211, 4.3, 4.9)
        'Flächen mit Bohrungsgrößen herausfiltern
        For i = 0 To UBound(aussen_Arr) Step 1
            Dim oFace As Face
            For Each oFace In oResult.InterferenceBody.Faces
                If oFace.SurfaceType = kCylinderSurface And oResult.InterferenceBody.Faces.Count = 4 Then
                    If Round(oFace.Geometry.Radius * 2 * 10, 5) = aussen_Arr(i) Then
                        ThreadVorhandenLarge = True
                        Set oCylinderFaceLarge = oFace
                        Set oCylinderLarge = oFace.Geometry
                    End If
                    If Round(oFace.Geometry.Radius * 2 * 10, 5) = kern_Arr(i) Then
                        ThreadVorhandenSmall = True
                        Set oCylinderFaceSmall = oFace
                        Set oCylinderSmall = oFace.Geometry
                    End If
                End If
            Next
            If ThreadVorhandenLarge = True And ThreadVorhandenSmall = True Then Exit For
        Next
        'Prüfen, ob Kerndurchmesser beidseitig offen ist
        'Prüfen, ob Bohrungen konzentrisch
        Dim Clash As Boolean
        Clash = True
            If Round(oCylinderLarge.BasePoint.DistanceTo(oCylinderSmall.BasePoint), 5) <> 0 Then
                Dim oSlaintVector As Vector
                Set oSlaintVector = oCylinderLarge.BasePoint.VectorTo(oCylinderSmall.BasePoint)
                If oSlaintVector.IsParallelTo(oCylinderSmall.AxisVector.AsVector) Then
                    Clash = False
                End If
            Else
                Clash = False
            End If
        End If
        Dim ThreadLengthClash As Boolean
        ThreadLengthClash = False
        'Längencheck durch Volumenprüfung
        If ThreadVorhandenLarge = True And ThreadVorhandenSmall = True And Clash = False Then
            Dim VolumeLarge As Double
            VolumeLarge = 4 * Atn(1) * ((oCylinderLarge.Radius) ^ 2 - (oCylinderSmall.Radius) ^ 2) * oCylinderLarge.Radius * 2 * 2
            Dim VolumeSmall As Double
            VolumeSmall = 4 * Atn(1) * ((oCylinderLarge.Radius) ^ 2 - (oCylinderSmall.Radius) ^ 2) * oCylinderLarge.Radius * 2
            If oResult.Volume > VolumeLarge Or oResult.Volume < VolumeSmall Then
                ThreadLengthClash = True
            End If
        End If
        'Body hinzufügen
        If Clash = True Then
            If oTotalBodyRed Is Nothing Then
                Set oTotalBodyRed = oResult.InterferenceBody
            Else
                Call ThisApplication.TransientBRep.DoBoolean(oTotalBodyRed, oResult.InterferenceBody, kBooleanTypeUnion)
            End If
        End If
        If ThreadLengthClash = True And Clash = False Then
            If oTotalBodyThreadLength Is Nothing Then
                Set oTotalBodyThreadLength = oResult.InterferenceBody
            Else
                Call ThisApplication.TransientBRep.DoBoolean(oTotalBodyThreadLength, oResult.InterferenceBody, kBooleanTypeUnion)
            End If
        End If
        If ThreadLengthClash = False And Clash = False Then
            If oTotalBodyGreen Is Nothing Then
                Set oTotalBodyGreen = oResult.InterferenceBody
            Else
                Call ThisApplication.TransientBRep.DoBoolean(oTotalBodyGreen, oResult.InterferenceBody, kBooleanTypeUnion)
            End If
        End If
    Next
    'Neues Teil erstellen (nicht sichtbar)
    Dim oResultPartRed As PartDocument
    If Not oTotalBodyRed Is Nothing Then
        If oResultPartRed Is Nothing Then Set oResultPartRed = ThisApplication.Documents.Add(kPartDocumentObject, "M:\PDS2014\Templates\Norm.ipt", False)
        'Set oResultPart = ThisApplication.Documents.Add(kPartDocumentObject, ThisApplication.FileManager.GetTemplateFile(kPartDocumentObject), False)
    End If
    Dim oResultPartGreen As PartDocument
    If Not oTotalBodyGreen Is Nothing Then
        If oResultPartGreen Is Nothing Then Set oResultPartGreen = ThisApplication.Documents.Add(kPartDocumentObject, "M:\PDS2014\Templates\Norm.ipt", False)
    End If
    Dim oResultPartYellow As PartDocument
    If Not oTotalBodyThreadLength Is Nothing Then
        If oResultPartYellow Is Nothing Then Set oResultPartYellow = ThisApplication.Documents.Add(kPartDocumentObject, "M:\PDS2014\Templates\Norm.ipt", False)
    End If
    Dim oFeature As PartFeature
        Set oFeature = oResultPartRed.ComponentDefinition.Features.NonParametricBaseFeatures.Add(oTotalBodyRed)
        oFeature.Name = "TotalBodyRed"
    End If
        Set oFeature = oResultPartGreen.ComponentDefinition.Features.NonParametricBaseFeatures.Add(oTotalBodyGreen)
        oFeature.Name = "TotalBodyGreen"
    End If
        Set oFeature = oResultPartYellow.ComponentDefinition.Features.NonParametricBaseFeatures.Add(oTotalBodyThreadLength)
        oFeature.Name = "oTotalBodyThreadLength"
    End If
    'Occurrence erstellen
    Dim trans As Matrix
    Set trans = ThisApplication.TransientGeometry.CreateMatrix
    If Not oResultPartRed Is Nothing Then
        Set oOcc = oAsmCompDef.Occurrences.AddByComponentDefinition(oResultPartRed.ComponentDefinition, trans)
        Call oOcc.SetRenderStyle(kOverrideRenderStyle, oAsmDoc.RenderStyles.Item("ACAD-Rot"))
        oOcc.Name = "Kollisionen"
    End If
    If Not oResultPartGreen Is Nothing Then
        Set oOcc = oAsmCompDef.Occurrences.AddByComponentDefinition(oResultPartGreen.ComponentDefinition, trans)
        Call oOcc.SetRenderStyle(kOverrideRenderStyle, oAsmDoc.RenderStyles.Item("ACAD-Grün"))
        oOcc.Name = "Geprüft"
    End If
    If Not oResultPartYellow Is Nothing Then
        Set oOcc = oAsmCompDef.Occurrences.AddByComponentDefinition(oResultPartYellow.ComponentDefinition, trans)
        Call oOcc.SetRenderStyle(kOverrideRenderStyle, oAsmDoc.RenderStyles.Item("ACAD-Gelb"))
        oOcc.Name = "Gewinde zu kurz oder zu lang"
    End If
End Sub
You have to change the path of the templatefile. Or you can activate the three lines with the "GetTemplateFile". In IV2014 the "GetTemplateFile" make some trouble so I don't use it.
GeorgK
That's great. I add this to my code. Thank you very much.
@ekinsb please add this to the collision check in Autodesk Inventor 2017.
