collect Propertysets in vb.net
k14348
k14348
   I have attached screenshot of vb.net debug and locals window. i could able to get only count of propertysets. Unable to view all propertysets in locals window. What could be the issue. Can anyone help on this...
-Karth
k14348
    Error:Cannot find the interop type that matches the embedded type 'Inventor.PropertySets'. Are you missing an assembly reference?
How to resolve this?
 using inventor 2015 .net frame work 4.5. i have selected target frame work as 4.5 also.
-Karth
Sergio.D.Suárez
Hi, the first thing I would try would be to size the property differently. I think since it is in black it is not taking courage.
Could you modify the definition of the property as below?
Dim Prop As Inventor.Property = PropSets.Item("Design Tracking Properties")
Hope this helps with your problem. Cheers!
Please accept as solution and give likes if applicable.
I am attaching my Upwork profile for specific queries.
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
k14348
Hi @Sergio.D.Suárez ,
                         Still there is an issue. I made all setup whatever i read in forums. Still i couldn't see object tree in locals. SS attached.
-Karth
