Coding For dropdown in Ilogic Form.
smanionDV2GJ
smanionDV2GJ
Hi, I am trying to make a parametric in Inventor that allows me to choose Half Lap, Full, Lap or Corner To Corner from a drop down menu in an ilogic form and changes a corner seam value. My current code that I've pasted below will only run the code for the corner to corner. I have tried with and without the multivalue update code and I get the same results. How can I remedy this?
If
Style = "HALF LAP" Then Parameter("Corner1") = 0.5 Parameter("Corner2") = 0.5 Parameter("Corner3") = 0.5 Parameter("Corner4") = 0.5 MultiValue.UpdateAfterChange = True Else If Style = "FULL LAP" Then Parameter("Corner1") = 0.2 Parameter("Corner2") = 0.2 Parameter("Corner3") = 0.2 Parameter("Corner4") = 0.2 MultiValue.UpdateAfterChange = True Else If Style = "CORNER TO CORNER" Then Parameter("Corner1") = 1 Parameter("Corner2") = 1 Parameter("Corner3") = 1 Parameter("Corner4") = 1 MultiValue.UpdateAfterChange = True End If
A.Acheson
Welcome to the forum. Can you show a screenshot of the multi value parameter style or the whole dialogue box? If possible please provide the .ipt file as well. Are you running this rule as internal/external?
Regards
Alan
WCrihfield
I assume that the unquoted word "Style" in your rule is representing a 'local' (within the same document as the rule) parameter.  If not then you may have to change how it is being used.
Here is a slightly alternative code, where I've added most update type lines of code in their proper places.
'Update the current document when this rule finishes running.
iLogicVb.UpdateWhenDone = True
'The model will be updated after every Parameter change within the current rule.
Parameter.UpdateAfterChange = True
'The model will be updated after every MultiValue Parameter is changed within the current rule.
If Style = "HALF LAP" Then
ElseIf Style = "FULL LAP" Then
ElseIf Style = "CORNER TO CORNER" Then
End If
'Output Parameters values from this rule to the Model. (Use this before Document Update)
RuleParametersOutput()
'Immediately update the current document.
iLogicVb.DocumentUpdate()
Wesley Crihfield
(Not an Autodesk Employee)
Curtis_Waguespack
 Hi @smanionDV2GJ ,
Attached is an Inventor 2019 file using this code that works as expected. Maybe you can examine this file and maybe it will become clear why it works in it and not in your file.
I hope this helps.
Curtis
	oValue = 0.5
	oValue = 0.2
	oValue = 1
End If
For i = 1 To 4
	Parameter("Corner" & i) = oValue
Next
