Code required to get Windows user login name
jlane
jlane
What is the iLogic code (or VB.NET code) I could use within a rule to get the Windows user login name?  Similar to AutoLISP's (getvar "LOGINNAME").
Thx!
Accepted solutions (3)
ekinsb
.Net supports getting the username but it's probably easier to just use Inventor's API.  This will get it:
ThisApplication.UserName
Brian Ekins
Mod the Machine blog
NachoShaw
Hi
If you want the windows user login name, you can use
dim sUserName As String
SUserName = Environ("Username")
Cheers
Nacho
Automation & Design Engineer
Inventor automation Programmer (C#, VB.Net / iLogic)
Furniture, Sheet Metal, Structural, Metal fab, Tradeshow, Fabrication, CNC
jlane
Thanks Brian, that worked!
jlane
Thanks nmjshaw150, that worked too!
