split table
split table
ChrisAtherton
split table
ChrisAtherton
Quick question:
I cant see it in the API but does anyone know away of seeing if a custom table on a drawing is split and at which row?
Chris Atherton
IEng MIMechE BEng Hons
Design Automation Services Manager | Symetri
https://uk.linkedin.com/in/chrissoathe
YuhanZhang
You can use below VBA to get query if a custom table is split:
Sub CustomTableSplitData()
    Dim oDoc As DrawingDocument
    Set oDoc = ThisApplication.ActiveDocument
    ' In UI you select a custom table first
    Dim oTable As CustomTable
    Set oTable = oDoc.SelectSet(1)
    On Error Resume Next
    ' iNum is sections count
    Dim iNum As Long: iNum = 0
    iNum = oTable.NumberOfSections
    If iNum = 1 Then
        MsgBox "The custom table is not split!"
        End
    If iNum > 1 Then
        Dim lRowsOfEachSection As Long
        Dim dNum As Double, dTest As Double
        dNum = oTable.Rows.Count
        dTest = oTable.Rows.Count / iNum
        lRowsOfEachSection = oTable.Rows.Count / iNum
        If (dTest - lRowsOfEachSection) >= 0.5 Then
            lRowsOfEachSection = lRowsOfEachSection + 1
        If Not oTable.WrapLeft Then
            MsgBox "The custom table is split into " & iNum & " sections:" & vbCrLf _
                 & "The left section has " & lRowsOfEachSection & " rows."
            End
        Else
            lRowsOfEachSection = oTable.Rows.Count - lRowsOfEachSection * (iNum - 1)
            End
    Dim lMaxRows As Long: lMaxRows = 0
    lMaxRows = oTable.MaximumRows
    If lMaxRows = 0 Then
        End
    Else
        iNum = oTable.Rows.Count / lMaxRows
        If iNum * lMaxRows < oTable.Rows.Count Then iNum = iNum + 1
                 & "The left section has " & lMaxRows & " rows."
        Else
            Dim lLeftSectionRows As Long
            lLeftSectionRows = oTable.Rows.Count - lMaxRows * (iNum - 1)
                 & "The left section has " & lLeftSectionRows & " rows."
End Sub
Hope this helps.
If this solves the problem please click ACCEPT SOLUTION so other people can find it easily.
Rocky Zhang
Inventor API PD
Manufacturing Solutions
Autodesk, Inc.
ChrisAtherton
Hi and thanks for that.
Reading through the code my understanding is that this will tell me if the table has been "split at row" ... this is different to doing a split table which creates a seperate table?  Is that right?
Thanks Chris
Chris Atherton
