code for opening folder
hi
i need some help in opening a specific folder and user can select the file using vba.
i need to include it in the rest of my macro.
please help Smiley Frustrated
Curtis_W
Hi  akosi,
Here is an example:
Public Sub TestFileDialog()
    ' Create a new FileDialog object.
    Dim oFileDlg As FileDialog
    Call ThisApplication.CreateFileDialog(oFileDlg)
    ' Define the filter to select part and assembly files or any file.
    oFileDlg.Filter = "Inventor Files (*.iam;*.ipt)|*.iam;*.ipt|All Files (*.*)|*.*"
    ' Define the part and assembly files filter to be the default filter.
    oFileDlg.FilterIndex = 1
    ' Set the title for the dialog.
    oFileDlg.DialogTitle = "Open File Test"
    ' Set the initial directory that will be displayed in the dialog.
    oFileDlg.InitialDirectory = "C:\Temp"
    ' Set the flag so an error will be raised if the user clicks the Cancel button.
    oFileDlg.CancelError = True
    ' Show the open dialog.  The same procedure is also used for the Save dialog.
    ' The commented code can be used for the Save dialog.
    On Error Resume Next
    oFileDlg.ShowOpen
'    oFileDlg.ShowSave
    ' If an error was raised, the user clicked cancel, otherwise display the filename.
    If Err Then
        MsgBox "User cancelled out of dialog"
    ElseIf oFileDlg.FileName  "" Then
        MsgBox "File " & oFileDlg.FileName & " was selected."
    End If
End Sub
This example came from here:
I hope this helps.
Curtis
thanks a lot Smiley Happy
this code doesnt work for me...
it doesnt point to whatever i put as the initial directory.
help help help!!!Smiley Frustrated
