Code for looking for missing drawings
felix.bouchard
felix.bouchard
Hi, i would like a code that can check if every parts and assemblies contained i a main assembly have a drawing linked to it.
I would like every content center parts to be excluded.
i need to look in this folder C:\3D Novathermboiler LOCAL
Thanks.
Curtis_Waguespack
Hi @felix.bouchard ,
Here is an example that will report which drawings exists for the models in the active assembly file.
I hope this helps.
Curtis
Dim NoDrawingList As String
Dim HasDrawingList As String
Dim oDoc As Document = ThisApplication.ActiveDocument
If oDoc.DocumentType <> DocumentTypeEnum.kAssemblyDocumentObject Then Exit Sub
For Each xDoc As Document In oDoc.AllReferencedDocuments
	oPath = IO.Path.GetDirectoryName(xDoc.FullFileName)
	oModelName = IO.Path.GetFileName(xDoc.FullFileName)
	oName = IO.Path.GetFileNameWithoutExtension(xDoc.FullFileName) & ".idw"
	oDrawingFilePath = oPath & "\" & oName
	If System.IO.File.Exists(oDrawingFilePath) = True Then
		HasDrawingList = HasDrawingList & vbLf & oModelName
	Else
		NoDrawingList = NoDrawingList & vbLf & oModelName
	End If
Next
MsgBox("has drawing:" & vbLf & HasDrawingList & vbLf & vbLf & "has NO drawing:" & vbLf & NoDrawingList, , "iLogic")
felix.bouchard
This is great, is there a way to exclude the content center parts?
Thanks.
Curtis_Waguespack
ooops! I thought I had that in there. ( I wrote this using a different method at first and then changed my mind and apparently dropped the CC line in doing so).
Give this a try ( note, I didn't test it just now, so post back it this doesn't work).
I hope this helps.
Curtis
	If xDoc.DocumentType = DocumentTypeEnum.kPartDocumentObject Then
		If xDoc.ComponentDefinition.IsContentMember = True Then Continue For
	End If
	Else
	End If
Next
