Close Documents Documents opened by API
amitnkukanur
amitnkukanur
I am doing a customization in inventor 2012 using vb.net as development language.
I am opening and closing the documents in background, in this process some of documents are left open and not closed as the result draughtsman is not able to change the project. Even though active document is closed inventor show few documents in extreme right bottom corner.
My problem is am tring to figure out how to close these active documents. I am trying to find out Active Document closing event if any.
Requesting to provide a idea to this problem on how i can close those documents which i opened using API in single shot
Cheers,
Amit
Senior Software Engineer
Hi Amit,
Below three steps might help you out.
  1. You can have a List containing filename's which are opened using API and the close them by using Document.Close
  2. You can iterate through the Documents object and see if there are any visible documents, if not perform Document.CloseAll
  3. Rather than keeping all the documents which are opened using API in session, why don't you close them once your work is done.
You can use Documents.CloseAll to close all in a single shot.
What operations are performed by the documents which are opened using API also matters....
amitnkukanur
Hi Santosh,
Thanks for reply.
I used the Documents.CloseAll to close all open documents in a single shot by creating a new button
Cheers,
Amit
Hi amitk
i have the similar problem but i not have idea how to resolve, you may shared your code or your solution....please?
thank you!
Hola amitk
tengo el mismo problema pero yo no tengo idea de cómo resolver, usted puede compartir su código o su solución .... por favor?
Gracias!
hi, where did you find Documents.CloseAll
