ClientView IDW
ClientView IDW
NachoShaw
Advisor Advisor
ClientView IDW
NachoShaw
Hi
I managed to get this working in a previous application but the identical code does not work.... I get an error
Exception thrown: 'System.Runtime.InteropServices.COMException' in mscorlib.dll
on this line
m_PopoView.Update(False)
Here is my full code
    Private Sub LoadImage()
        Dim sSheet As Integer = 0
        m_oDrawingDocument = m_oServer.Open(s)
        m_PopoView = m_oDrawingDocument.Sheets.Item(1).ClientViews.Add(PictureBox1.Handle.ToInt32())
        m_PopoCamera = m_PopoView.Camera
        m_PopoCamera.Perspective = False
        m_PopoCamera.Fit()
        m_PopoCamera.Apply()
        Try
            m_oDrawingDocument.Close()
            m_oDrawingDocument = Nothing
        Catch ex As Exception
        End Try
    End Sub
and here a version I found from Sanjay that also doesn't work....
    Dim oSvr As InventorApprentice.ApprenticeServerComponent
    Dim oAppDoc As InventorApprentice.ApprenticeServerDrawingDocument
    Dim oClientView As InventorApprentice.ClientView
    Private Sub Form_Load()
        Dim filename As String = "I:\2017\Z Templates\company\company - Drawing Sheet.idw"
oSvr = New Inventor.ApprenticeServerComponent oAppDoc = oSvr.Open(filename) Dim oSheet As Inventor.Sheet oSheet = oAppDoc.Sheets.Item(1) oClientView = oSheet.ClientViews.Add(PictureBox1.Handle.ToInt32()) End Sub Private Sub loadimage() Dim oCamera As InventorApprentice.Camera oCamera = oClientView.Camera oCamera.Fit() oCamera.Perspective = False oCamera.Apply() Me.Refresh() End Sub Private Sub Form_Paint() oClientView.Update(False) End Sub
Any ideas what might cause the issue and how I can rectify it?
cheers
Nacho
Nacho
Automation & Design Engineer
Inventor automation Programmer (C#, VB.Net / iLogic)
Furniture, Sheet Metal, Structural, Metal fab, Tradeshow, Fabrication, CNC
NachoShaw
Well....
No matter what apprentice method I use, I get the exact same error. furthermore, an earlier separate application that did work just fine in 2017 no longer works. All of the samples (including my live application) error on this line
and the error is
Catastrophic failure (Exception from HRESULT: 0x8000FFFF (E_UNEXPECTED))
I have tried everything from threading to using the inventor viewer all of which return the same error.
So,
is this an error in Inventor? Are there some additional files that are required? I have copied over the following files over to the 2017 folder
adskassetapi_new-5.2.dll
adskassetapi_new-15.dll
libeay32_Ad_1.dll
ssleay32_Ad_1.dll
the project is currently x86 platform
I will obviously need to get this fixed in my existing application too... Anyone else had experience with this and managed to fix it?
Cheers
Nacho
Nacho
itB9559
Hi, Sorry to reply to an old topic, but did you ever find a solution to this?
