ClientFeature.AddDependency
Message 1 of 1
I am trying to implement a clientfeature that needs to update when the geometry it references updates,
from what i understand i need to set IsCustomSolved = true, and set its dependency to the reference geometry by using ClientFeature.Definition.AddDependency()
when i try to call AddDependency() i get a an ArgumentException when i pass it a sketch/work axis etc.
        public static void Main()
            var app = (Inventor.Application)System.Runtime.InteropServices.Marshal.GetActiveObject("Inventor.Application");
            var doc = (AssemblyDocument)app.ActiveDocument;
            var def = doc.ComponentDefinition;
            var sketch = def.Sketches[1];
            var clientfeaturedef = def.Features.ClientFeatures.CreateDefinition("TestFeature");
            clientfeaturedef.IsCustomSolved = true;
            var clientFeature = def.Features.ClientFeatures.Add(clientfeaturedef, "someid");
            clientFeature.Definition.AddDependency(sketch);
 am i doing something wrong here?
Replies (0)
