Client Graphics
Client Graphics
GeorgK
Advisor Advisor
Message 1 of 11
Client Graphics
GeorgK
Hello together,
how could I colorize my userdefined workaxis with client graphics?
Thank you
Georg
Replies (10)
Message 2 of 11
chandra.shekar.g
Autodesk Support
Autodesk Support
Hi @GeorgK,
Try the following VBA code to create client graphics for workaxis.
Currently, code works for Assembly document.
Sub Main()
    Dim doc As AssemblyDocument
    Set doc = ThisApplication.ActiveDocument
    Dim compDef As AssemblyComponentDefinition
    Set compDef = doc.ComponentDefinition
    Dim wa As WorkAxis
    Set wa = ThisApplication.CommandManager.Pick(kWorkAxisFilter, "Select a work axis to draw client graphics")
    Dim oClientGraphics As ClientGraphics
    Dim oDataSets As GraphicsDataSets
    On Error Resume Next
    Set oClientGraphics = compDef.ClientGraphicsCollection.Item("TestGraphicsID")
    Set oDataSets = doc.GraphicsDataSetsCollection.Item("TestID")
    If Err.Number = 1 Then
    On Error GoTo 0
        ' An existing client graphics object was successfully obtained so clean up.
        Set oClientGraphics = compDef.ClientGraphicsCollection.Add("TestGraphicsID")
        Set oDataSets = doc.GraphicsDataSetsCollection.Add("TestID")
        ' update the display to see the results.
        ThisApplication.ActiveView.Update
    Else
        Call oClientGraphics.Delete
        Call oDataSets.Delete
    ' Create a new graphics node within the client graphics objects.
    Dim oSurfacesNode As GraphicsNode
    Set oSurfacesNode = oClientGraphics.AddNode(1)
    Dim coordSet As GraphicsCoordinateSet
    Set coordSet = oDataSets.CreateCoordinateSet(1)
    Dim oColorSet As GraphicsColorSet
    Set oColorSet = oDataSets.CreateColorSet(1)
    'Call oColorSet.Add(1, 255, 0, 0) ' For red
    Call oColorSet.Add(1, 0, 255, 0) 'For Green
    Dim oPointCoords(5) As Double
    If wa.Line.Direction.X > 0 Then
        oPointCoords(0) = wa.Line.RootPoint.X + 6
    Else
    If wa.Line.Direction.Y > 0 Then
        oPointCoords(1) = wa.Line.RootPoint.Y + 6
    Else
    If wa.Line.Direction.Z > 0 Then
        oPointCoords(2) = wa.Line.RootPoint.Z + 6
    Else
    oPointCoords(3) = wa.Line.RootPoint.X
    oPointCoords(4) = wa.Line.RootPoint.Y
    oPointCoords(5) = wa.Line.RootPoint.Z
    Call coordSet.PutCoordinates(oPointCoords)
    Dim oLine As LineGraphics
    Set oLine = oSurfacesNode.AddLineGraphics
    oLine.CoordinateSet = coordSet
    oLine.ColorSet = oColorSet
    oLine.LineWeight = 2
End Sub
Please feel free to contact if there is any doubt.
If solves problem, click on "Accept as solution" / give a "Kudo".
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
Message 3 of 11
GeorgK
Hello @chandra.shekar.g,
thank you very much. Your code is working for the main axis but not for userdefined axis. The client graphic is somewhere in space 🙂
Georg
Message 4 of 11
chandra.shekar.g
Autodesk Support
Autodesk Support
Hi @GeorgK
In the following screencast, demonstrated about creating client graphics to custom workaxis using VBA.
If there is any change, upload a screencast. I will look into it.
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Message 5 of 11
GeorgK
I have 2 different models. In the first one your code is not working and in the second one it works. Maybe the first model is corrupt. I use Inventor 2017.4.1.
With new models your code is working. Thank you very much.
Georg
Message 6 of 11
GeorgK
I did some more testing. The problem appears in different models. Also in new ones. Is this a bug?
Message 7 of 11
chandra.shekar.g
Autodesk Support
Autodesk Support
Hi @GeorgK,
Is it possible to share the model (Non confidential one)?
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Message 8 of 11
GeorgK
@chandra.shekar.g
The model where the axis are in the wrong orientation.
Message 9 of 11
chandra.shekar.g
Autodesk Support
Autodesk Support
Hi @GeorgK,
Check the following VBA code
Sub Main()
    Dim wa As WorkAxis
    On Error GoTo 0
    Else
    'Call oColorSet.Add(1, 0, 255, 0) 'For Green
    If wa.Line.Direction.X = 1 Or wa.Line.Direction.Y = 1 Or wa.Line.Direction.Z = 1 Then
        If wa.Line.Direction.X = 0 Then
        ElseIf wa.Line.Direction.X > 0 Then
        If wa.Line.Direction.Y = 0 Then
        ElseIf wa.Line.Direction.Y > 0 Then
        If wa.Line.Direction.Z = 0 Then
        ElseIf wa.Line.Direction.Z > 0 Then
    Else
        oPointCoords(0) = wa.Line.RootPoint.X - 6
        oPointCoords(1) = wa.Line.RootPoint.Y - 6
        oPointCoords(2) = wa.Line.RootPoint.Z - 6
    Dim oTransform As Matrix
    Set oTransform = ThisApplication.TransientGeometry.CreateMatrix
    Call oTransform.SetCoordinateSystem(wa.Line.RootPoint, wa.Line.Direction.AsVector, wa.Line.Direction.AsVector, wa.Line.Direction.AsVector)
    If wa.Line.Direction.X < 0 Or wa.Line.Direction.Y < 0 Or wa.Line.Direction.Z < 0 Then
        oSurfacesNode.Transformation = oTransform
End Sub
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Message 10 of 11
GeorgK
thank you very much. Now are the axis aligned. But the lenght and the orientation are different. Is there any possibility to get the same lengt as the workaxis? How could I get the start and endpoint of the workaxis (WorkAxis.GetSize)?
Georg
Message 11 of 11
chandra.shekar.g
Autodesk Support
Autodesk Support
Hi @GeorgK,
Yes, WorkAxis.GetAxis() is good API to create LineGraphics of same length and orientation.
Try the following modified VBA code.
Sub Main()
    Dim wa As WorkAxis
    On Error GoTo 0
    Else
    Dim startPnt As Point
    Dim endPnt As Point
    Call wa.GetSize(startPnt, endPnt)
    oPointCoords(0) = startPnt.X
    oPointCoords(1) = startPnt.Y
    oPointCoords(2) = startPnt.Z
    oPointCoords(3) = endPnt.X
    oPointCoords(4) = endPnt.Y
    oPointCoords(5) = endPnt.Z
End Sub
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
