Client Graphics Color change
FINET_Laurent
Advisor Advisor
FINET_Laurent
Hi folks,
I'm drawing a nice cylinder in an assembly environement using the client graphics with this code :
Dim doc As Inventor.AssemblyDocument = ThisApplication.ActiveDocument
Dim acd As Inventor.AssemblyComponentDefinition = doc.ComponentDefinition
Dim tg As Inventor.TransientGeometry = ThisApplication.TransientGeometry
Dim treb As Inventor.TransientBRep = ThisApplication.TransientBRep
Dim p1 As Inventor.Point = tg.CreatePoint(0, 0, 0)
Dim p2 As Inventor.Point = tg.CreatePoint(0, 0, 100)
Dim sfb As Inventor.SurfaceBody = treb.CreateSolidCylinderCone(p1, p2, 10, 10, 10)
Dim cg As Inventor.ClientGraphics = acd.ClientGraphicsCollection.Add("Test")
Dim n As Inventor.GraphicsNode = cg.AddNode(1)
Dim s As Inventor.SurfaceGraphics = n.AddSurfaceGraphics(sfb)
ThisApplication.ActiveView.Update
I would like to change it's color to transparent blue by code. I've been playing with color properties but with no luck.
Kind regards,
FINET L.
If this post solved your question, please kindly mark it as "Solution"
If this post helped out in any way to solve your question, please drop a "Like"
@LinkedIn     @JohnCockerill
WCrihfield
Hi @FINET_Laurent.  I'm just guessing here, but there are a few properties I am seeing that may be worth checking out.
SurfaceGraphics.Color (the fourth Color spec is for opacity).
GraphicsNode.Appearance
GraphicsNode.IsTransparentInPlaceEdit
GraphicsNode.OverrideOpacity
Wesley Crihfield
(Not an Autodesk Employee)
FINET_Laurent
Hi @WCrihfield
I've been playing with  SurfaceGraphics.Color, GraphicsNode.IsTransparentInPlaceEdit, GraphicsNode.OverrideOpacity
..with no actual result. I might be missing something, but the color property is throwing errors & the others have no visual effects.. I indeed started digging the appearances assets & came with this :
'Change Appearance -----------------------------------------------------
Dim targetAppearance As Asset
Try
	targetAppearance = doc.Assets.Item("Water-008")
Catch
	Dim sourceAppearance As Asset = ThisApplication.AssetLibraries.Item(2).AppearanceAssets.Item("Water-008")'
	sourceAppearance.CopyTo(doc)
End Try
n.Appearance = targetAppearance
It is an ok result as for now but I'm still hoping for something else.. for instance using the .color property which looks better suited..
Kind regards,
FINET L.
