Checking for Error Using Method Intent
inulobo
inulobo
How do I check if a value has errored in an if statement. I have tried numerous methods to deal with the error but nothing has worked for me so far. The dimension is floating and invisible on the page. Attached is set to true. The only way I can see that the dimension is bad is through the method intent. I have attached images below.
Dim oOrdinateDim As OrdinateDimension
Set oOrdinateDim = oDrawingDim
If IsError(oOrdinateDim.Intent.Geometry.Parent.Name) = True Or oOrdinateDim.Attached = False Then
oDrawingDim.Delete
End If
JelteDeJong
did you try "On Error GoTo". Something like this...
On Error GoTo ErrorHandler
    oDrawingDim.Delete
  End If
Exit Sub
ErrorHandler:
   MsgBox("Something went wrong! Do something about it.")
Resume Next
Jelte de Jong
Blog: hjalte.nl - github.com
inulobo
I actually wrote something very similiar. Still did not work. For some reason it just always goes to that one line and continues to tell me the error message. I want to delete the dimension because it has that error. It weird that it doesn't seem to work.
