Does the error happen to the line:
oNode = oPane.GetBrowserNodeFromObject(oSketch)
If so seems the browser node for the hidden sketch is not available, so you can try below code:
Dim oCompdef As PartComponentDefinition
oCompdef = ThisDoc.Document.ComponentDefinition
Dim oPane As BrowserPane
oPane = ThisDoc.Document.BrowserPanes("PmDefault")
Dim MsgBody As String
Dim AboveEoP_SkCount As Integer=0
For Each oSketch As Sketch In oCompdef.Sketches
On Error Resume Next
Dim oNode As BrowserNode
If Err.Number=0 Then
If oSketch.HealthStatus <> HealthStatusEnum.kBeyondStopNodeHealth Then
SkCount = AboveEoP_SkCount + 1
MsgBody = MsgBody & " " & oSketch.Name & " - " & oSketch.IsOwnedByFeature & vbCrLf
Else
Exit For
End If
Else
Err.Clear
On Error GoTo 0
End If
Next
MsgBox (MsgBody,,"Out of " & oCompdef.Sketches.Count & " sketches " & AboveEoP_SkCount & " are placed above EoP: ")
If you want to get the deeper level browser nodes, you can iterate the BrowserNode.BrowserNodes. But if the browser node for the sketch is not available you may not find it via API.
If this solves the problem please click ACCEPT SOLUTION so other people can find it easily.
Rocky Zhang
Inventor API PD
Manufacturing Solutions
