check/uncheck override text model box
Message 1 of 8
HI! Sorry for my english. How I can check/uncheck the override text model check box in tolerance dialog (for a dimension in a .idw document), in a DLL add in. Is possible, or inventor api not include this possibility. Help me. Thanks.
Replies (7)
Message 2 of 8
Unfortunately, the API currently does not support this. This will be
addressed in a future release.
Sanjay-
wrote in message news:[email protected]...
Thanks.
Message 3 of 8
...lot of thanks, Sanjay! I began to become crazy!
Message 4 of 8
Ktelang
I was wondering whether
this functionality is added to 2012
Config :: Intel (R) Xeon (R) CPU E31245 @ 3.30 GHz, 16.0 GB, 64bit win7
Inventor 2013 and Vault Basic 2013
Message 5 of 8
Curtis_W
Hi Ktelang,
This was added at some point.
You can find an example using ilogic to look at these properties here:
http://inventortrenches.blogspot.com/2011/06/using-ilogic-to-find-dimension.html
I hope this helps.
Curtis
Message 6 of 8
Ktelang
Thanks Curtis,
Actually I am trying to override a modelvalue
by scalefactor 3
Say modelvalue is 39" I want override display value as
the result of 39*3 =117"
Please can you take a look at the code below, I am stuck
at the oLenDim.OverrideModelvalue= Modval
It is not dispalying the correct override value in "
I know that inventor default value is in cm I have converted
it to inches.
Thanks in advance..
' Check whether the Drawing document is active document.
If ThisApplication.ActiveDocumentType <> kDrawingDocumentObject Then
MsgBox ("Please have the Drawing document open")
Exit Sub
End If
Dim OrDoc As DrawingDocument, OrDocSheet As Sheet
Set OrDoc = ThisApplication.ActiveDocument
Set OrDocSheet = OrDoc.Sheets("Sheet:1")
Dim oLenDim As GeneralDimension, oDLODim As GeneralDimension
Set oLenDim = OrDocSheet.DrawingDimensions.GeneralDimensions.Item(1)
'Add some formatted text to all dimensions on the sheet.
oLenDim.HideValue = False
Dim ModVal As Double, DimScale As Double
DimScale = 3
ModVal = oLenDim.ModelValue
ModVal = ModVal / 2.54
ModVal = ModVal * 3
'Debug.Print ModVal
oLenDim.OverrideModelValue = ModVal
Message 7 of 8
Ktelang
I see the problem in the last 2 steps in the code
Till  ModVal = ModVal * 3
'Debug.Print ModVal
The ModVal = correct as expected
But during
The multiplier #3 is some what treated and converted to inches
so we end up getting the product of ModVal in inches x 3 in inches
(i.e. something around 1.1811)
Does Anyone know a way by which I can define a unitless constant
Might be basic but have not done this thing before
Thanks a lot
Message 8 of 8
Ktelang
Nevermind I figured out
Sub Overridevalue()
Exit Sub
End If
Dim ModVal As Double, DimScale As Integer
DimScale = 3
ModVal = ModVal * 3
End Sub
Sharing for others..
