Check for iproperty value
bob_clark5J5M8
bob_clark5J5M8
Hi, hope someone can help, it's been a few years since I did any iLogic
The company I am in uses custom iprops for the revision of drawings
e.g.
REV1
REV2
REV3
REV4
REV5
I would like to check if there is a value in REV5, If nothing then check if a value exists in REV4 etc.
When a value is found, write the value to  iProperties.Value("Project", "Revision Number") and stop searching for any other values.
Can someone kindly help pls?
Many thanks )
WCrihfield
Maybe something like this would help you in that situation?
oDoc = ThisDoc.Document
oCProps = oDoc.PropertySets.Item("Inventor User Defined Properties")
If oCProps.Count = 0 Then Exit Sub
Dim oRevPropNames As New List(Of String)
For Each oCProp As Inventor.Property In oCProps
	If oCProp.Name.StartsWith("REV")
		oRevPropNames.Add(oCProp.Name)
	End If
Next
If oRevPropNames.Count = 0 Then Exit Sub
oRevPropNames.Sort 'alpha/numeric normal order
oRevPropNames.Reverse 'reverse order (REV5 before REV4)
Dim oVal As String = ""
For Each oPropName In oRevPropNames
	oVal = CStr(oCProps.Item(oPropName).Value)
	If oVal = "" Then
		Continue For
	Else
		Exit For
	End If
Next
oDoc.PropertySets.Item("Inventor Summary Information").Item("Revision Number").Value = oVal
If this solved your problem, or answered your question, please click ACCEPT SOLUTION.
Or, if this helped you, please click (LIKE or KUDOS) 👍.
If you want and have time, I would appreciate your Vote(s) for My IDEAS :bulb: or you can Explore My CONTRIBUTIONS
Wesley Crihfield
(Not an Autodesk Employee)
bob_clark5J5M8
perfect, very tidy, thank you
