Check Feature Suppression
jfenter
jfenter
I have an iLogic code to change the direction of a rectangular pattern as shown here:
Dim oDoc As PartDocument
oDoc = ThisApplication.ActiveDocument
Dim oDef As PartComponentDefinition
oDef = oDoc.ComponentDefinition
	If zeroCorner = "LEFT" Then
	oDef.Features.RectangularPatternFeatures("Rectangular Pattern1").Definition.NaturalXDirection = True
	oDef.Features.RectangularPatternFeatures("Rectangular Pattern2").Definition.NaturalXDirection = True
	oDef.Features.RectangularPatternFeatures("Rectangular Pattern3").Definition.NaturalXDirection = True
		Else
			oDef.Features.RectangularPatternFeatures("Rectangular Pattern1").Definition.NaturalXDirection = False
			oDef.Features.RectangularPatternFeatures("Rectangular Pattern2").Definition.NaturalXDirection = False
			oDef.Features.RectangularPatternFeatures("Rectangular Pattern3").Definition.NaturalXDirection = False
	End If
Subsequently, I have rules in place to suppress the rectangular patterns within the part.  When the code given above is ran while the patterns are suppressed Inventor immediately crashes, losing all work.  I would like to add a try/catch to check the suppression of the patterns before the change in direction takes place, but am having trouble finding an answer.
I'm assuming something like this will work, but have not had any luck:
Try
	oDef.Features.RectangularPatternFeatures("Rectangular Pattern1").GetSuppressionCondition
	Catch
	MessageBox.Show("Make pattern active before executing change.", "Error")
	End Try
How can I check that the rectangular pattern is active before changing the direction of the pattern?  Thanks!
JhoelForshav
You could just set it to active if its not already like this
If Feature.IsActive("Rectangular Pattern1") = False Then Feature.IsActive("Rectangular Pattern1") = True
Would that work for you? 🙂
