in the Inventor API / Programming help, there is this VBA example
Public Sub CreateSheetMetalStyle()
' Set a reference to the sheet metal document.
' This assumes a part document is active.
Dim oPartDoc As PartDocument
Set oPartDoc = ThisApplication.ActiveDocument
' Make sure the document is a sheet metal document.
If oPartDoc.SubType "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}" Then
MsgBox "A sheet metal document must be open."
Exit Sub
' Get the sheet metal component definition. Because this is a part document whose
' sub type is sheet metal, the document will return a SheetMetalComponentDefinition
' instead of a PartComponentDefinition.
Dim oSheetMetalCompDef As SheetMetalComponentDefinition
Set oSheetMetalCompDef = oPartDoc.ComponentDefinition
' Create a new unfold method.
Dim okFactorUnfoldMethod As UnfoldMethod
Set okFactorUnfoldMethod = oSheetMetalCompDef.UnfoldMethods.AddLinearUnfoldMethod("kFactorTest", "0.43")
' Create a new unfold method using a bend table.
Dim oTableUnfoldMethod As UnfoldMethod
On Error Resume Next
Set oTableUnfoldMethod = oSheetMetalCompDef.UnfoldMethods.AddBendTableFromFile("Table Sample", "C:\Program Files\Autodesk\Inventor 2010\Design Data\Bend Tables\Bend Table (in).txt")
If Err Then
MsgBox "Unable to load bend table"
On Error Goto 0
' Copy a sheet metal style to create a new one. This arbitrarily uses the
' first style in the collection.
Dim oStyle As SheetMetalStyle
Set oStyle = oSheetMetalCompDef.SheetMetalStyles.Item(1).Copy("Sample Style")
' Set the value for the thickness. This is an expression that will be used to
' set a parameter when this style is activated.
oStyle.Thickness = ".1 in"
' The name "Thickness" as used below is handled specially when the style
' is used so it will behave as expected for all languages.
oStyle.BendRadius = "Thickness * 1.5"
oStyle.BendReliefDepth = "Thickness * 1.5"
oStyle.BendReliefShape = kRoundBendReliefShape
oStyle.BendReliefWidth = "Thickness / 2"
oStyle.BendTransition = kArcBendTransition
oStyle.BendTransitionArcRadius = "Thickness * 2.0"
oStyle.CornerReliefShape = kRoundCornerReliefShape
oStyle.CornerReliefSize = "Thickness * 2.0"
oStyle.MinimumRemnant = "Thickness * 2.0"
' Set the material. For this example it arbitrarily uses the first material in the collection.
oStyle.Material = oPartDoc.Materials.Item(1)
oStyle.PunchRepresentationType = kFormedFeaturePunchRepresentation
oStyle.ThreeBendCornerReliefShape = kFullRoundCornerReliefShape
oStyle.ThreeBendCornerReliefSize = "Thickness * 2.0"
' Activate this style.
oStyle.Activate
' This section will override some of the settings defined by the style.
Dim bOverrideStyle As Boolean
bOverrideStyle = True
If bOverrideStyle Then
' Set the unfold method to use the unfold method created above.
oSheetMetalCompDef.UnfoldMethod = okFactorUnfoldMethod
' Set the thickness.
oSheetMetalCompDef.UseSheetMetalStyleThickness = False
oSheetMetalCompDef.Thickness.Expression = ".12 in"
' Set the material.
oSheetMetalCompDef.Material = oPartDoc.Materials.Item(2)
End Sub
If this answers your question then please select "Accept as Solution"
Kudo's are also appreciated
Succes on your project, and have a nice day
Herm Jan
