Changing "AllowCustomValues" for a parameter, based on another parameter
casper.vorm
casper.vorm
Hi all.
I am trying to create a model where users can either select a value from a predetermined list or toggle another parameter to make a "special" version, where they can enter an arbitrary value.
I have made a simple example of what im trying to do:
Sub main
	Dim x As UserParameter = Parameter.Param("param_1")
	If Special = True Then
		x.ExpressionList.AllowCustomValues = True
	Else
		x.ExpressionList.AllowCustomValues = False
	end if
End Sub
However, when "special" changes, the parameter is updated but nothing has changed in the form. E.g the property  "AllowCustomValues" is now true, but it still cant be edited in the form, or vice versa.
I have attached a simple model that demonstrates my problem.
Thanks in advance!
-Casper
A.Acheson
Hi @casper.vorm
I havent looked at the attachment so this is just an observation of your initial goal.  This could be a restriction in how the form sees parameters. The form has internal options that are altered when you add the parameter. Can you achieve the same functionality by the manual change of the allowcustomvalues toggle? If you can this can be done by code. If not then that's the limitation of the form/parameter interaction.
Wouldn't setting the custom value to true and the user just typing in custom values when needed do the trick for you? The multivalue list is still shown regardless.
Regards
Alan
WCrihfield
Hi @casper.vorm.  The problem in this specific situation is that there is also a similar setting within the settings of that ComboBox within the Form itself, which is also for allowing custom values or not.  And you can not change that value in the Form's settings from the iLogic rule, or from changing that setting of the parameter itself.
Wesley Crihfield
(Not an Autodesk Employee)
casper.vorm
Hi again, thank you for your replies.
@A.Acheson Yes, that is an option. In the model I am trying to create, the model have parameters that needs to be computed based on the selected values when special = false. These are computed by some formulas that should only run when special = false, so it would be nice if I could prevent users from typing in that case.
@WCrihfield I see, then I will have to find another approach.
Thank you for your help!
-Casper
