Changing Positional Representation Error
ahmed.hagi
ahmed.hagi
I'm trying to change a positional representation of a subassembly with the API, but I run into this error, "Unspecified error (Exception from HRESULT: 0x80004005(E_FAIL):
It is odd because I am able to change the representation of the subassembly manually.
For Each oCompOcc In oCompDef.Occurrences
			If Component.IsActive("REJECT DEVICE:1") = True Then
				If oCompOcc.Name = "REJECT DEVICE:1" Then
					oCompOcc.ActivePositionalRepresentation = "Master" 'Fails at this point
				End If
			End If
		Next
JelteDeJong
I could reproduce this error only if the PositionalRepresentation name did not exist. You can try the following rule. This will check if the PositionalRepresentation with the name exsits.
Dim doc As AssemblyDocument = ThisDoc.Document
Dim oCompDef = doc.ComponentDefinition
Dim representationName = "Master"
Dim occName = "REJECT DEVICE:1"
For Each oCompOcc As ComponentOccurrence In oCompDef.Occurrences
    If oCompOcc.Name = occName Then
        If Component.IsActive(occName) = True Then
            Dim def As AssemblyComponentDefinition = oCompOcc.Definition
            Dim reps = def.RepresentationsManager.PositionalRepresentations.
                Cast(Of PositionalRepresentation).
                Where(Function(p) p.Name = representationName).ToList()
            If (reps.Count = 0) Then
                MsgBox(occName & " does not have a PositionalRepresentation called: " & representationName)
			Else
				oCompOcc.ActivePositionalRepresentation = representationName 'Fails at this point
            End If
        End If
    End If
Next
Jelte de Jong
Blog: hjalte.nl - github.com
ahmed.hagi
Thanks so much for your reply. I tried modifying the code to include your count.
It comes up with this:
Followed by this:
It is odd that it would say this because the sub assembly definitely has this positions:
Any other ideas?
A.Acheson
Here is a post discussing this. If you keep the same name you can change them manually or by code as they become linked. Or use the override "PositionalRepresentation.SetPositionalRepresentationOverride"
Regards
Alan
ahmed.hagi
Thanks for the reply! I've already looked at that post, doesn't help my scenario, the positional representation I am trying to access is only in the subassembly, not the top level assembly. That approach won't really work because I need to maintain the master position in the top level and only change the subassembly...
el_jefe_de_steak
Is it possible that there is an extra space in the positional rep name compared to the text you are searching for?
ahmed.hagi
I double checked the name and string for differences. There are none 😞
