Changing BOM Quantity of Components in Assembly
eric.frissell26WKQ
Message 1 of 1
eric.frissell26WKQ
Hi guys, took a look around the forums and didn't find a good solution for trying to change the BOM quantity of components.  Currently I have parts in folders in an assembly and I loop through the folders to suppress all components and then unsuppress others if they meet the criteria for unsuppression which is whether or not the part number contains a specific size.  The suppression/unsuppression is handled by a single function and the function suppresses ~ 20 parts, then unsuppresses 2.  What I'd like is if I can access the BOM quantities from the way this is set up -
Overloads function SuppressFolder(uSuppPart as string, suppFolder as string)
Dim oAssDoc As Inventor.AssemblyDocument = ThisDoc.Document
	Dim oBrowserFolder As Inventor.BrowserFolder
	Dim oBrowserPane As Inventor.BrowserPane = oAssDoc.BrowserPanes.Item("Model")
	Dim oFolder As BrowserFolder
	Dim size As Integer
	oFolder = oBrowserPane.TopNode.BrowserFolders.Item(suppFolder)
	oFolderNodes = oFolder.BrowserNode.BrowserNodes
	For Each oNode As BrowserNode In oFolderNodes
		oComp = oNode.NativeObject
		partNo = Left(oComp.Name, Len(oComp.Name)-2)
		oComp.Suppress
        uSupp = InStr(oComp.Name, uSuppPart, vbTextCompare)
        If uSupp <> 0 then oComp.Unsuppress
Any chance it's possible to start setting BOM quantities?  Given that there's 2 parts with the same name that'll get unsuppressed, you could pass in a component quantity to the function, and then handle the quantity with something like
If oComp.BomQuantity <> ComponentQuanty then oComp.BomQuantity = ComponentQuantity
Naturally BomQuantity isn't an object but is there any way to write something like that?
Replies (0)
