Change the parameters of a custom ipart inserted into an assembly
oransen
oransen
Is it possible to change the parameters of a custom ipart in an assembly after it has been inserted, or can I only do an insert using AddCustomiPartMember?
In that case I simply remove the previous occurrence and insert a new one I suppose?
xiaodong_liang
Autodesk Support
Autodesk Support
you can use ComponentOccurrence.ChangeRowOfiPartMember to change the row in the iPartTable this iPartMember represents. even the method allows you to input the custom params.
