Capture active window
Hello guys,
I`m looking for the code which will capture the active window similar to iProperties-->Save--> Capture
Any help appreciated,
Thank you,
Alex.
ekinsb
To capture the current window you can use the following VBA code.
Public Sub SaveCurrentWindow()
    Dim window As View
    Set window = ThisApplication.ActiveView
    Call window.SaveAsBitmap("C:\Temp\IVWindow.png", 0, 0)
End Sub
 The type of image file created depends on the file extension of the filename provided.  The last two arguments are the width and height of the image in pixels.  In this example I used zero for both wich indicates it should use the current window size for both the height and width.  I can also do something like this (filename, 0, 3000).  This indicates that the width of the image will be 3000 pixels and the height will be whatever is required to maintain the same aspect ratio as the window your using to create the image.  If you specifiy full values, for example (filename, 2000, 3000) then you'll get an image that specific size.
Brian Ekins
Mod the Machine blog
Brian, thank you.
I want something a little different. Basically I`m talking about the preview picture. I`d like this captured image stay with the part, so next time I open it I see what it is.
I can go to iProperties--> Save --> Active Window--> Capture to do this, but I want this to be done automatically.
Is this possible?
ekinsb
Here's a slight variation of the previous program that will do what you want.
Public Sub SaveCurrentWindowAsThumbnail()
    Dim window As View
    Dim filename As String
    filename = "C:\Temp\IVWindow.png"
    Call window.SaveAsBitmap(filename, 250, 250)
    Dim doc As Document
    Set doc = ThisApplication.ActiveDocument
    Call doc.SetThumbnailSaveOption(kImportFromFile, filename)
End Sub
Brian Ekins
Thanks a lot!
