Change Text Color at Drawing Sketch Symbol
dgreatice
dgreatice
Anyone can help me to get the right code below, i cant change text color at drawing Sketch Symbol like the picture.
Public Sub EditSymbols()
Dim odoc As DrawingDocument
Set odoc = ThisApplication.ActiveDocument
Dim osymb As SketchedSymbolDefinition
Dim oColor As Color
Set oColor = ThisApplication.TransientObjects.CreateColor(0, 0, 0)
oColor.ColorSourceType = ColorSourceTypeEnum.kLayerColorSource
Dim oText As TextBox
Dim x As Long
x = 0
Dim y As Long
y = 0
For Each osymb In odoc.SketchedSymbolDefinitions
x = x + 1
Set osymb = odoc.SketchedSymbolDefinitions.Item(x)
Dim oSketch As DrawingSketch
Call osymb.Edit(oSketch)
For Each oText In osymb.Sketch.TextBoxes
y = y + 1
Set oText = osymb.Sketch.TextBoxes.Item(y)
oText.Color.ColorSourceType = ColorSourceTypeEnum.kLayerColorSource
Next
y = 0
osymb.ExitEdit (True)
Next
End Sub
Please use the ACCEPT AS SOLUTION or KUDOS button if my Idea helped you to solve the problem.
Autodesk Inventor Professional Certified 2014
dgreatice
Anyone can help me?
dgreatice
Request anwer, please. Thanks
I had the same issue I was cleaning up blocks and there are a lot of them. I wanted to change the textboxes to bylayer.
The following is iLogic code, but you can the skeleton and apply it to your vb code
I had to use item(x) format in order for it to work.. not sure why...
On Error Resume Next
iLogicVb.UpdateWhenDone = True
Dim oDoc As DrawingDocument = ThisApplication.ActiveDocument
Dim oColor As color
Dim oSymDefName As String
Dim x As Integer = 1
Dim y As Integer = 1
Dim oSymDef As SketchedSymbolDefinition
For Each SketchedSymbolDefinition In odoc.SketchedSymbolDefinitions
        oSymDefName = odoc.SketchedSymbolDefinitions.Item(x).Name 'gets the name of the block
        oSymDef = odoc.SketchedSymbolDefinitions.Item(oSymDefName) 'uses the name of the block
        oSymDef.Edit(oSketch)
        For Each TextBox In oSketch.TextBoxes
        oColor = oSketch.TextBoxes.Item(y).Color 'gets the current color
        oColor.ColorSourceType = ColorSourceTypeEnum.kLayerColorSource 'Makes the current color bylayer
        oSketch.TextBoxes.Item(y).Color = oColor  'assigns the color with bylayer
y=y+1 Next y=1 x=x+1 oSymDef.ExitEdit (True) Next
dgreatice
Thank for you code, its work.
I make simple code now.
    oDoc = ThisApplication.ActiveDocument
    Dim oColor As Color
    For Each osymb In oDoc.SketchedSymbolDefinitions
            oColor = oText.Color
            Dim Y As Long
            For Y = 1 To oSketch.TextBoxes.Count
                oSketch.TextBoxes.Item(Y).Color = oColor
            Next
        Next
    Next
JREVKAP8
I want do the the same, but for Sketch lines as well. I can't get it to work though. I tried simply replacing "textbox" with "sketchLine" in the code, but no luck.
Could you help me with this?
