Change source of 3rd party spreadsheet.
herrwolf1
herrwolf1
herrwolf1
Anyways,
Tab apparently goes straight to "Post Message"
To my problem.
The following code worked fine before I installed SP1. Can anyone spread some light onto what a solution might be.
Sub ChangeSource()
Dim oDoc As Document
Dim oFile As File
Dim oFileDesc As FileDescriptor
Dim Temp As String
Set oDoc = ThisApplication.ActiveDocument
Set oFile = oDoc.File
For Each oFileDesc In oFile.ReferencedFileDescriptors
If oFileDesc.FullFileName = MasterForm.lblPath.Caption & "\" & MasterForm.lblSpreadsheet.Caption Then
Temp = MasterForm.lblPath.Caption & "\" & MasterForm.lblSpreadsheet.Caption
oFileDesc.ReplaceReference (Temp) ' The code breaks here
End If
Next
End Sub
You are missing the 'Call' keyword in the
following line:
should be:
Call oFileDesc.ReplaceReference (Temp)
This is a VB syntax oddity that has been
addressed in VB.NET.
Sanjay-
herrwolf1
Hello Sanjay,
I tried adding the Call keyword. It didn't work. Here is the error I get:
Run-time error '-2147467259 (80004005)':
Method 'ReplaceReference' of object ' _IRxFileDescriptor' failed
Perhaps I have other problems.
Hmm, I tried again and it works for me. Are you on
Inventor 2009? Perhaps you have an incorrect filepath to your
spreadsheet?
Also, if you intend to change the source of the
spreadsheet linked via the Parameters dialog, there is another way:
Sub ChangeExcelSource()
    Dim oDoc As
PartDocument
    Set oDoc =
    Dim
oDef As PartComponentDefinition
    Set oDef =
oDoc.ComponentDefinition
    Dim oTable
As ParameterTable
    Set oTable =
oDef.Parameters.ParameterTables(1)
oTable.FileName = "C:\temp\test_copy.xls"
End
Sub
Sanjay-
snichols
Can this be done in an Inventor 2009 .dwg also? I have a linked spreadsheet that is the parts list and I would like to change the source via a macro. I am not very good at VBA so please be gentle.
