Change size - Content Center
CCarreiras
Mentor Mentor
Message 1 of 25
CCarreiras
Hi!
I use this vb routine to change Content Center sizes within a family of elements.
In previous versions it work very well, but now it's working very erratic.
Any sugestions to solve this, or tips for a better method to do this operation?
Conditions:
Change the size of a Standard Content Center part (no need to change to a different family, only the size)
The Content center is in a custom folder inside the project folder
The size is changed based in the change of a parameter inside main asssembly
The parts are in the first level of the main assembly, not in a sub-aasembly.
Test attached.
Also check the video to resume the issue.
Thanks a lot for your help.
I'm not a power programer, and now i'm lost... i used this method in a few iLogic assemblys, and now i can't make them work well.
CCarreiras
Replies (24)
Message 21 of 25
GeorgeWilliams
Has this been resolved in 2018 or later?  Are there any workarounds for this issue?
I'm getting the same issue on Inventor 2018 3.2.  The API will find the "Other Parts" node but no other nodes... I need the Tube & Pipe child node.  Works fine if I call it individually but does not work if I call it from code on a bunch of components.  Should I reorder the calls and get the Tube & Pipe components first?
George Williams
D3 Technologies - Automation Solutions
If this post helps, please click the "thumbs up" to give kudos
If this post answers your question, please click "Accept as Solution"
Message 22 of 25
I asked for an correction in the API but no positive reponds received.
Message 23 of 25
adam.nagy
Autodesk Support
Autodesk Support
It's supposed to have been fixed in Inventor 2020.
Please let us know if you can confirm this on your side as well.
Adam Nagy
Autodesk Platform Services
Message 24 of 25
GeorgeWilliams
I was able to workaround this issue in 2018 r3.2 by implementing a dictionary with the Key = FullTreeViewPath and Value = TheContentTreeViewNode.
For each set of ChildNodes that I queried for a given level of a CC path, I added all those ChildNodes to that collection and then just used that dictionary to "jump" to a given level.  Works great.
George Williams
Message 25 of 25
very useful code. How can I edit for DIN933 and DIN934
