Change sheet metal styles from an assembly for selected parts.
anilkumar279
anilkumar279
hi,
I want to set sheet metal active style from with help of input list box.
assembly 999-A.iam
Sub assembly 999-B.iam
Part in sub assembly
999-1.ipt
999-2.ipt
999-3.ipt
999-4.ipt
 only for -1,-2 & -3 ipt.
Please help me.
SyntaxEditor Code Snippet
oCompDef = ThisDoc.Document.ComponentDefinition
oAssyOccurrences  = oCompDef.Occurrences
Dim oOccurrence As ComponentOccurrence
Dim oSubOccurrence1 As ComponentOccurrence
For Each oOccurrence In oAssyOccurrences
If oSubOccurrence.Definition.Document = "999-1.ipt" AndAlso platte_selected = "4 mm" Then
oSubOccurrence.SheetMetal.SetActiveStyle ="_4 mm S355MC"
chandra.shekar.g
Autodesk Support
Autodesk Support
Hi @anilkumar279,
In the previous code, what is meaning of "platte_selected = "4 mm"".
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
anilkumar279
Hi, I have a input list box this comes from there.
chandra.shekar.g
Autodesk Support
Autodesk Support
Hi @anilkumar279,
Try the following iLogic code. Needs some modification based on your situation.
Dim oDoc As AssemblyDocument
oDoc = ThisApplication.ActiveDocument
Dim oDef As AssemblyComponentDefinition
oDef = oDoc.ComponentDefinition
Dim oSheetDef As SheetMetalComponentDefinition
Dim oStyle As SheetMetalStyle
For Each occ As ComponentOccurrence In oDef.Occurrences.AllLeafOccurrences
    If occ.Definition.Document.DisPlayName = "999-1.ipt" AndAlso platte_selected = "4 mm" Then
        oSheetDef = occ.Definition
        For Each oStyle In oSheetDef.SheetMetalStyles
            If oStyle.Name = "_4 mm S355MC" Then
                oStyle.Activate()
            End If
        Next
    ElseIf occ.Definition.Document.DisplayName = "999-2.ipt" AndAlso platte_selected = "5 mm" Then
            If oStyle.Name = "_5 mm S355MC" Then
                oStyle.Activate()
            End If
        Next
    ElseIf occ.Definition.Document.DisplayName = "999-3.ipt" AndAlso platte_selected = "6 mm" Then
            If oStyle.Name = "_6 mm S355MC" Then
                oStyle.Activate()
            End If
        Next
    End If
Next
Please feel free to contact if there is any queries.
If solves problem, click on "Accept as solution" / give a "Kudo".
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
