Attached is a rule that checks and modifies bends if needed.
SyntaxEditor Code Snippet
Dim smDef As SheetMetalComponentDefinition = ThisDoc.Document.ComponentDefinition
Dim uom As UnitsOfMeasure = ThisDoc.Document.UnitsOfMeasure
Dim chkRadius As String = InputBox("Enter Bend Radius: ", "Title", smDef.BendRadius.Expression)
Dim chkRadiusValue As Double = uom.GetValueFromExpression(chkRadius, "cm")
Dim featSet As HighlightSet = ThisDoc.Document.CreateHighlightSet()
Dim oRed As Color = ThisApplication.TransientObjects.CreateColor(255, 0, 0)
oRed.Opacity = 0.80
featSet.Color = oRed
For Each pf As PartFeature In smDef.Features
Dim doAdd As Boolean = False
Select Case pf.Type
Case ObjectTypeEnum.kFlangeFeatureObject
If Not pf.BendFeature Is Nothing Then
If Not EqualWithinTolerance(pf.BendFeature.Definition.BendRadius.Value, chkRadiusValue, .001) Then doAdd = True
End If
Case ObjectTypeEnum.kContourFlangeFeatureObject
End If
Case ObjectTypeEnum.kFaceFeatureObject
End If
Case ObjectTypeEnum.kHemFeatureObject
End If
Case ObjectTypeEnum.kBendFeatureObject
Case ObjectTypeEnum.kFoldFeatureObject
End If
Case Else
'Do Nothing
End Select
If doAdd Then
featSet.AddItem(pf.BendFeature)
End If
Next
If featSet.Count > 0 Then
If DialogResult.Yes = MessageBox.Show("Highlighted Features has an incorrect bend radius. Would you like to fix them?", "Check Bends", MessageBoxButtons.YesNo) Then
For Each bf As BendFeature In featSet
bf.Definition.BendRadius.Expression = chkRadius
Next
End If
End If
featSet.Clear()
featSet = Nothing
InventorVb.DocumentUpdate()
