Change selection mode in assembly via API
jan.pomplun
jan.pomplun
I would like to know if it is possible to change the selection behaviour
https://knowledge.autodesk.com/support/inventor-products/learn-explore/caas/CloudHelp/cloudhelp/2014...
in an assembly via the API?
rikard.nilsson
The link did not work but I think you should search in API Help for "SelectionFilterEnum Enumerator"
There you can finnd all the different filters that you need for selection..
/Rikard
jan.pomplun
Dear Rikard,
thanks for the quick answer. However, for my problem I do not want to set a selection filter when choosing parts via tha API (e.g. via Pick).
I would like to change the "global" selection mode in an inventor assembly to "Parts" via the API. The following pic shows the corresponding menu (sorry, its German) in the inventor GUI. Using EventWatcher, I tried to find if this command fires some event, but no luck.
So, can these menu entries be activated via the API?
Jan
rikard.nilsson
OK..
I haven't done this but I think this is what you are looking for,,
SelectionPriorityEnum Enumerator
to use in
AssemblyDocument.SelectionPriority Property
/Rikard
jan.pomplun
Thanks!!
As always, once you know it, it seems quite obvious 🙂
Inventor.SelectionPriorityEnum.kPartSelectionPriority
did it.
