Announcement: We’re aware of an issue affecting starting a new topic from category pages and creating new blog posts. New topics can still be started directly from the relevant board. Learn more here.
Change Parts List Style with iLogic
Message 1 of 8
I need iLogic code to change the Parts List Style. Here's what I'm starting with:
Dim oDrawDoc As DrawingDocument
oDrawDoc = ThisApplication.ActiveDocument
Dim oSheet As Sheet
oSheet = oDrawDoc.ActiveSheet
Dim oPartslist As PartsList
oPartslist = oSheet.PartsLists(1)
oPartsList.Style = oDrawDoc.StylesManager.PartsListStyles.Item("PartsList(MyStyleName)")
But it's not working. I get the error message, "The Parameter is Incorrect. (Exception from HRESULT: 0x80070057 (E_INVALIDARG))
Any ideas?
Replies (7)
Message 2 of 8
Ktomberlin
It looks like it should work, as long as "Parts​List(MyStyleName)" is actually a parts list in your active drawing.
Dim openDoc As Document
   'assumes a drawing document is active.
    'Set a reference to the active sheet.
    Dim oSheet As Sheet
    'Look for partlist within drawing. End rule, if it doesn't exist.
    'say there is a Partslist on the sheet.
    If oSheet.PartsLists(1) IsNot Nothing Then
        'set parts list to a specific style
        oPartsList.Style = oDrawDoc.StylesManager.PartsListStyles.Item("Material List (ANSI)")
     End If
Message 3 of 8
My style name was "MyStyleName," not "PartsList(MyStyleName)." Silly me. Thanks.
Message 4 of 8
By the way, could you quickly explain for me what the (1) was for in PartsList(1) and why it's general practice to create these variables named oDrawDoc and oSheet? Or are they even variables? I see them so often, I'm starting to think they're iLogic syntax...
Message 5 of 8
Curtis_Waguespack
See link:
http://forums.autodesk.com/t5/inventor-customization/ilogic-a-couple-syntax-questions/m-p/6407238#M6...
Message 6 of 8
Baha, thanks, I hadn't gotten an email notification of your response.
Message 7 of 8
Curtis_Waguespack
No worries, and my apologies for all of they typos in that reply. Smiley Frustrated  Hopefully it makes some bit of sense. Smiley Embarassed
Message 8 of 8
don't sweat it, it clears everything up perfectly.
