Change orthographic to perspective projection using iLogic
Message 1 of 8
i would like to be able to change the projection type from orthogonal to perspective and vice versa using iLogic code. It is critical for the project I'm working on and the potential users that this can be controlled via an iLogic form. I have seen another post relating to this -
"How to change Projection from Orthographic to Perspective View using VB.Net code" - but it didn't work on my computer. I'm really new to iLogic and don't know how to make it work.
Can anyone help?
Replies (7)
Message 2 of 8
Hey there,
Did you copy and paste the code from the other post?  That's not iLogic code but it's very close.
SyntaxEditor Code Snippet
Dim oCam as Camera
oCam = ThisApplication.ActiveView.Camera
oCam.Perspective = Perspective
oCam.ApplyWithoutTransition()
I created a Boolean parameter called Perspective.  Modifying that will change your camera from Perspective to Orthographic.
Message 3 of 8
Thank you! I didn't know vb.net codes are different than iLogic (you see how naive  am with this!)
Anyway, the code you provided didn't work right away - I think you created a text parameter (not boolean) with one of the multivalue being perspective?
I amended the code for boolean and changed the code slightly to make it work - and now it works like a charm!
Thank you very much for your help - the way to call the perspective function under camera is just the pick me up I needed.
Here is the amended code:
Dim oCam as Camera
If Perspective = True Then
oCam.Perspective = True
ElseIf Perspective = False Then
oCam.Perspective = False
End If
Message 4 of 8
No, it was a boolean.  It just makes the code cleaner and not as much of it.
You'll notice I don't use an If..Then.  Since Perspective was a boolean parameter, you can just set the oCam.Perspective to equal that parameter.
Glad you got it to work though.
Message 5 of 8
That's a really helpful little tip - thank you!
Message 6 of 8
Maxim-CADman77
I wonder if it possible to modify code in order set view mode to "perspective with ortho faces"?
Please vote for Inventor-Idea Text Search within Option Names
Message 7 of 8
R.Mabery
Oh how I wish there was.
Randy Mabery
Applications Expert
IMAGINiT Technologies
Message 8 of 8
Maxim-CADman77
