Change Degrees or Curvature or Continuity G0, G1, G2, G3 from a Curve with API
florian_wenzel
florian_wenzel
Inventor 2024
API Visual Studio C# or VB.NET
i have a Question,  is there a way to modify or change the Curvature of the Curve.
I think in Inventor as Default is G3, correct me if im wrong.
Is there a Way to Change this for example to G2 or G1 etc...
I was found nothing in CurveEvaluator and etc...
here some Links: Autodesk Inventor 2D surface curvature comb graphs (cadsetterout.com)
https://www.youtube.com/watch?v=LySx2At5yZs
Code:
// only begining
using Inventor;
using System;
using System.IO;
using System.Collections.Generic;
using System.Linq;
using System.Text;
using System.Threading.Tasks;
using Microsoft.Win32;
using System.Runtime.CompilerServices;
using System.Runtime.InteropServices;
using System.Windows.Forms;
using InvAddIn;
using Part_Code_CS;
namespace InvAddIn
    internal class CommandFunctionButton_18
        public static void CommandFunctionfweButton_18()
            PartDocument oPartDoc = (PartDocument)Globals.g_inventorApplication.ActiveDocument;
            PartComponentDefinition oCompDef = oPartDoc.ComponentDefinition;
            TransientGeometry oTG = Globals.g_inventorApplication.TransientGeometry;
            TransientObjects oTO = Globals.g_inventorApplication.TransientObjects;
            TransientBRep oBRep = Globals.g_inventorApplication.TransientBRep;
            MeasureTools oMeasureTools = Globals.g_inventorApplication.MeasureTools;
            CommandManager oCommandManager = Globals.g_inventorApplication.CommandManager;
            Sketch3D oSketch_A = oCompDef.Sketches3D.Add();
            Sketch3D oSketch_B = oCompDef.Sketches3D.Add();
            Point oPoint_A = oTG.CreatePoint(1, 4, 0);
            Point oPoint_B = oTG.CreatePoint(4, 1, 0);
            Point oPoint_C = oTG.CreatePoint(1, 1, 0);
            ObjectCollection oObjColl = oTO.CreateObjectCollection();
            oObjColl.Add(oPoint_A);
            oObjColl.Add(oPoint_C);
            oObjColl.Add(oPoint_B);
            SketchControlPointSpline3D oSpline = oSketch_A.SketchControlPointSplines3D.Add(oObjColl);
            BSplineCurve oBSplineCurve = oSpline.Geometry;
            CurveEvaluator oCurveEvaluator = oBSplineCurve.Evaluator;
Thanks for any Sugestion
florian_wenzel
Correct me if im wrong, maybe i understand here something wrong.
I want to reach a Goal something like this:
 and now i realize, that i need 2 ControlPoints and it will Solve the Problem 🙂
Question, is Possible to get a Result like the Red Curve, but only with One ControlPoint ?
Even Changing the G3 to G2 or G1, will change here Something, when i have 3 Points as Input?
I mean, StartPoint, EndPoint and One ControlPoint.
Or is this so, that since i will have minimum 2 ControlPoints, it will have a influance the G3 or G2 or G1?
Michael.Navara
I'm not sure you can modify the SketchControlPointSpline when position of control points are fully constrained.
Possible solution can be when you use SketchSpline instead. Then you can get point handles and edit them as you need.
