Change color of whole part based on Iproperties
jocean_vieiraZ9YQS
jocean_vieiraZ9YQS
I have tried to piece a few rules that I saw online together but without luck!
So I'm trying to get a part, inside an assembly, that has the description "Special" in Iproperties. And subsequently, make it red to create a visual signal that it needs a part number before being released.
Dim asmDoc As AssemblyDocument
asmDoc = ThisApplication.ActiveDocument
Dim occ As ComponentOccurrence
For Each iProperties.Value("Stock Number") = "Special"
	asmDoc.RenderStyles.Item("Red"))
Next
WCrihfield
Hi @jocean_vieiraZ9YQS.  Give this iLogic rule example a try, and see if it works OK for you.  It only works on top level components right now though.
Sub Main
	Dim oADoc As AssemblyDocument = TryCast(ThisDoc.Document, Inventor.AssemblyDocument)
	If oADoc Is Nothing Then Return
	Dim oOccs As ComponentOccurrences = oADoc.ComponentDefinition.Occurrences
	If oOccs.Count = 0 Then Return
	For Each oOcc As ComponentOccurrence In oOccs
		Dim sStockNumber As String = iProperties.Value(oOcc.Name, "Project", "Stock Number")
		If sStockNumber = "SPECIAL" Then
			Component.Color(oOcc.Name) = "Red"
		End If
	Next oOcc
	oADoc.Update2(True)
End Sub
If this solved your problem, or answered your question, please click ACCEPT SOLUTION .
Or, if this helped you, please click (LIKE or KUDOS) 👍.
Wesley Crihfield
(Not an Autodesk Employee)
jocean_vieiraZ9YQS
Thanks, I ended up just making a few additions and it works perfect for me now.
 Sub Main
		If TypeOf oOcc.Definition.Document Is PartDocument Then
			If sStockNumber = "SPECIAL" OrElse sStockNumber = "" Then
				Component.Color(oOcc.Name) = "PINK"
			End If
		End If
	Next oOcc
	oADoc.Update2(True)
End Sub
