Change BOM-Structure of files in a Folder
tcaG6GZK
tcaG6GZK
Hi Guys
Since we are switching to VAULT soon, we need to change the BOM structure of many components. The best way to do this is with iLogic i asume.
We have in our assemblies the purchased parts in the structure tree stored in folders - now an iLogic rule should be created, which changes the content of a certain folder - best ask for the folder name with a query-box - from "standard" to "purchase".
Can someone create me such a rule???
thank you very much!!!
Tom
Curtis_Waguespack
Hi @tcaG6GZK,
Something like this should work:
oPane = ThisApplication.ActiveDocument.BrowserPanes("Model")
oFolder = oPane.TopNode.BrowserFolders.Item("My_Folder")
'look at each item in the folder
For Each oNode As BrowserNode In oFolder.BrowserNode.BrowserNodes
	oComp = oNode.NativeObject
	oComp.BOMStructure = BOMStructureEnum.kPurchasedBOMStructure
Next
I hope this helps.
Curtis
tcaG6GZK
Hi Curtis
I´m sorry -but that does not work - there is an error message
but i cant declare the name of the folder in the routine - so there should be a different way to do the job
thx anyway!!
cheers
Tom
Curtis_Waguespack
Hi @tcaG6GZK ,
See this updated example. This will cycle through all of the browser folders, strip off BOM structure overrides, and set the component BOM structure to Purchased.
I hope this helps.
Curtis
For Each oFolder In oPane.TopNode.BrowserFolders
		oComp.BOMStructure = BOMStructureEnum.kDefaultBOMStructure 'remove BOMStructure override if present
		oComp.Definition.BOMStructure = BOMStructureEnum.kPurchasedBOMStructure
	Next
Next
tcaG6GZK
 Hi Curtis
it works so far!! thx a lot.
But as i said - it needs to be done on specific folders, not on every folder.
Is it possible to choose a folder by mousclick and then start the routine??
thx in advance
Tom
Curtis_Waguespack
Hi @tcaG6GZK
I hope this helps.
Curtis
Dim oSelected As ObjectCollection
oSelected = ThisApplication.TransientObjects.CreateObjectCollection
For Each oItem In ThisDoc.Document.SelectSet
	If oItem.Type = ObjectTypeEnum.kBrowserFolderObject Then oSelected.Add(oItem)
Next
'Check that at least 1 is selected
If oSelected.Count = 0 Then
	MsgBox("no folder selected", , "iLogic")
	Exit Sub 'exit rule
End if
For Each oItem In oSelected
	oFolder = oPane.TopNode.BrowserFolders.Item(oItem.name)
	Next
Next
tcaG6GZK
Ey Curtis
you made my day!!! it works perfect!!!
thx man!!!!
Cheers
Tom
