Change Appearance of solid with ilogic
Quoc_Kiet
Quoc_Kiet
Dear all,
In Part environments, I have a file mutiple solid, and using color ID: RGB 10 66 120, I want to go to Appearance edittor and uncheck Self illumination and change color ID to RGB 15 93 132 and applies to all solid with similar color codes.
Is there any ilogic expert here who can help me solve the above problem with ilogic
Thank you for reading my post.
Michael.Navara
You can use this code snippet. But I strongly recommend you to use tool like this VBA Object Browser for Inventor and look what the code means and how it works.
Dim part As PartDocument = ThisDoc.Document
'Set custom color
Dim generic_diffuse As ColorAssetValue = part.ActiveAppearance("generic_diffuse")
generic_diffuse.Value = ThisApplication.TransientObjects.CreateColor(10, 66, 120)
' Turn off the check box
Dim generic_self_illum_luminance As FloatAssetValue = part.ActiveAppearance("generic_self_illum_luminance")
generic_self_illum_luminance.Value = 0
nstevelmans
Hi, can you try this?
  Dim doc As PartDocument = ThisApplication.ActiveDocument
        Dim oColor As ColorAssetValue
        Dim a As Asset = Nothing
        Dim oTG As TransientObjects = ThisApplication.TransientObjects
		 ' loop all appearances
        For Each a In doc.Assets
            If a.AssetType = AssetTypeEnum.kAssetTypeAppearance Then
                oColor = a.Item("generic_diffuse")
                generic_self_illum_luminance = a.Item("generic_self_illum_luminance")
                If oColor.Value.Red = 10 Then
                    If oColor.Value.Green = 66 Then
                        If oColor.Value.Blue = 120 Then
                            oColor.Value = oTG.CreateColor(15, 93, 132)
                        End If
                    End If
                End If
                 End If
            Next
Quoc_Kiet
Hello @nstevelmans
Thank you for helping, but i find a orther solution from: VBA Macro - Change Part Colour Using RGB Values and resolved my issue, you can try it.
Have a great day.
