Chamfer Part Feature count
Message 1 of 13
If I select more than one edge for a single chamfer feature, the API (ChamferFeatures.Count) counts this as 1.
How would I go about obtaining the total amount of chamfered edges?
Replies (12)
Message 2 of 13
YuhanZhang
Not quite clear about the question, can you explain more about it? Or paste your code here so we can check if it works as expected?
If this solves the problem please click ACCEPT SOLUTION so other people can find it easily.
Rocky Zhang
Inventor API PD
Manufacturing Solutions
Autodesk, Inc.
Message 3 of 13
Hi @YuhanZhang
Thank you for your reply.
Please see the code below and the attached part as an example. In the example, I am looking for a result of 4 chamfers.
Dim oRefDoc As PartDocument = ThisApplication.ActiveDocument
' Get the referenced document component definition
Dim oCD As PartComponentDefinition = oRefDoc.ComponentDefinition
' Get the referenced document feature collection
Dim oFeatures As PartFeatures = oCD.Features
Dim oFeature As PartFeature
'  Get the referenced document feature count
Dim oFeatureCount As Integer = oFeatures.Count
'  Get the referenced document hole feature collection
Dim oHoles As HoleFeatures = oFeatures.HoleFeatures
'  Get the referenced document chamfer feature collection
Dim oChamfers As ChamferFeatures = oFeatures.ChamferFeatures
'Dim oChamferCount As Integer = oChamfers.Count
oChamferCount = oChamfers.Count
MsgBox(oChamferCount)
Message 4 of 13
YuhanZhang
So what you want to get is the count of chamfered edges but not the count of ChamferFeatures, below is a sample VBA code to get the chamfered edges' count, you can run it in VBA Editor with your data:
Sub GetChamferedEdgesCount()
    Set oRefDoc = ThisApplication.ActiveDocument
    Set oCD = oRefDoc.ComponentDefinition
    Set oFeatures = oCD.Features
    oFeatureCount = oFeatures.Count
    Set oHoles = oFeatures.HoleFeatures
    Set oChamfers = oFeatures.ChamferFeatures
    Dim oEdge As Edge
    Dim oChamferFeature As ChamferFeature
    For Each oChamferFeature In oChamfers
       ' move the feature under the End of Part node to get the chamfered edges.
       Call oChamferFeature.SetEndOfPart(True)
       MsgBox oChamferFeature.Name & " has " & oChamferFeature.Definition.ChamferedEdges.Count & " chamfered edges."
       For Each oEdge In oChamferFeature.Definition.ChamferedEdges
            oRefDoc.SelectSet.Select oEdge
       Next
       Call oChamferFeature.SetEndOfPart(False)
    Next
   ' MsgBox (oChamferCount)
End Sub
Hope it helps.
Rocky Zhang
Inventor API PD
Autodesk, Inc.
Message 5 of 13
Hi @YuhanZhang
I receive a run-time error '438'
Object doesn't support this property or method
On this line:
Message 6 of 13
I think it maybe should be:
For Each oEdge In oChamferFeature.Definition.Parent.ChamferedEdges
One problem I have with this code is the SetEndOfPart assignment. If my chamfer is in the middle of my model tree, then I lose all features after it. Is there a method to return to the previous position instead?
Message 7 of 13
YuhanZhang
The oChamferFeature.Definition.Parent.ChamferedEdges works too in this case, but it is actually the ChamferFeature.ChamferedEdges and it is hidden now, so I recommend to use the oChamferFeature.Definition.ChamferedEdges.
I added some lines to set the EndofPart node:
    ' get the original position of End of Part node.
    Dim oBefore As Object, oAfter As Object
    oCD.GetEndOfPartPosition oAfter, oBefore
    Dim oEdge As Edge
       Next
    Next
   ' restore the position of End of Part node.
    oAfter.SetEndOfPart False
End Sub
Rocky Zhang
Inventor API PD
Autodesk, Inc.
Message 8 of 13
two doubts about this solution.
1. If I paste it in the ilogic rule it doesn't work, how would it be adapted to ilogic?
2. To do the same but not only for chamfers, but also for rounding holes, ... Operations in which several entities can be selected at the same time, how would it be done?
Message 9 of 13
for hole and fillet for example
Message 10 of 13
YuhanZhang
The sample I provided is VBA code which is in VB6 style, while iLogic code is in VB.net style. To convert VBA code to iLogic, for most simple cases you just need to delete the "Set" keyword(which is to assign value to Object-based variable) in the code(some complex may require more edit). You can try it there to delete the "Set"  if it works.
For other features you can also calculate the edges that they use to create them, like what I demonstrated in the VBA code I calculated the ChamferedEdges, for other features you need to find proper properties to calculate the edges. For example the FilletFeature, you can calculate the FilletDefinition.EdgeSetItem and FaceSet and FullRoundSet etc. to calculate the edges.
Hope above helps.
Rocky Zhang
Inventor API PD
Autodesk, Inc.
Message 11 of 13
uo9K5H5
Hello, @YuhanZhang and @Anonymous I am trying to use your code to count every edge that I have selected for Fillet function. I am keep getting an error. Can you take a look in to the code?
    oCD.GetEndOfPartPosition (oAfter, oBefore)
	'Dim oChamfers As ChamferFeatures
    Dim oFillet As FilletFeatures
    oFillet = oFeatures.FilletFeatures
    oFilletCount = oFilletFeatures.Count
	Dim FilletFeatures = oFeatures.FilletFeatures
    Dim oEdge As Edge
    Dim oFilletFeatures As FilletFeatures
    For Each oFilletFeatures In oFillet
       Call ofilletFeatures.SetEndOfPart(True)
       MsgBox (oFilletFeatures.Name & " has " & oFilletFeatures.Definition.FilletEdges.Count & " chamfered edges.")
       For Each oEdge In oFilletFeatures.Definition.FilletEdges
            oRefDoc.SelectSet.Select (oEdge)
       Next
       Call oFilletFeatures.SetEndOfPart(False)
    Next
    oAfter.SetEndOfPart (False)
Message 12 of 13
YuhanZhang
@uo9K5H5  Please try below iLogic code:
Sub Main()
    oRefDoc = ThisDoc.Document
    Dim oFilletFeas As  FilletFeatures
    oFilletFeas = oFeatures.FilletFeatures
    Dim oFilletCount As Integer = oFilletFeas.Count
    oFilletCount = oFilletFeas.Count
    Dim oEdge As Edge
    Dim oFilletFeature As FilletFeature
    For Each oFilletFeature In oFilletFeas
       Call oFilletFeature.SetEndOfPart(True)
       oRefDoc.SelectSet.Clear
	   Dim iEdgeSetCount As Long
	   iEdgeSetCount = oFilletFeature.FilletDefinition.EdgeSetCount
	   Dim iEdgeCount As Long, iIndex As Long
	   iEdgeCount = 0
	   For iIndex = 1 To iEdgeSetCount
	       iEdgeCount = iEdgeCount + oFilletFeature.FilletDefinition.EdgeSetItem(iIndex).Edges.Count
	   Next
       MsgBox (oFilletFeature.Name & " has " & iEdgeCount & " fillet edges.",,"Inventor")
	   	 	Dim iEdgeIndex As Long
	   	   For iEdgeIndex = 1 To  oFilletFeature.FilletDefinition.EdgeSetItem(iIndex).Edges.Count
		   	   Dim oFilletEdge As Inventor.Edge
			   oFilletEdge = oFilletFeature.FilletDefinition.EdgeSetItem(iIndex).Edges(iEdgeIndex)
		   	   oRefDoc.SelectSet.Select(oFilletEdge)
		   Next
	   Next
       MsgBox("Edges were selected!",,"Inventor")
       Call oFilletFeature.SetEndOfPart(False)
    Next
End Sub
Rocky Zhang
Inventor API PD
Autodesk, Inc.
Message 13 of 13
uo9K5H5
@YuhanZhang  Thank you. It works like I wanted.
