Center Point of Hole Features - IV11
I'm trying to automate the creation of a hole table on an IDW, but it appears that the API doesn't yet support that. Because of this, I was planning to get the center points of all hole features in the model, create the table manually, and tag each hole in the appropriate view.
I can see how to get centers for Hole Features created by using a sketch. The problem is that if the feature was placed using Linear, Concentric, or Point references, there is no sketch.
It looks like I can get the Placement Definition of the Hole in the above three cases. For Concentric and Point, backing out the hole center should be easy - it's either the center point of the Circular reference or the location of the Workpoint.
The Linear reference is a bit more tricky, though - it seems I'm going to have to wrestle with the reference Edges and the distances to get the location of the point. Anyone know of an easier way to do this?
Have you tried the HoleFeature.HoleCenterPoints property? If I remember
correctly, this property returns sketch points if the feature is sketch
based and transient 'Point' objects if the hole placement is of any other
type.
Sanjay-
wrote in message news:5267944@discussion.autodesk.com...
Sanjay,
Thanks for the quick response. I actually just found this out now that I've got some code written around it. Looks like they'll actually be a little easier than the sketched holes.
