This is a fairly common issue. There are multiple ways to deal with it, but here is one of the simpler ways. Use an iLogic rule that will delete all the existing Centermarks on the sheet (or just a specified view), then recreate them using the 'Automated Centerlines' tool (simulated by the code). My example loops through every view on the 'active' sheet, deleting all the centermarks, then recreates them using that automated tool. I added a reference Sub in there, just to make sure that automated tool is set-up the way you want it (in case you don't regularly use it and don't already have it set-up the way you like). Then either run the rule manually, or set it up to run when some event happens (such as the one called "Dawing View Change" within the Event Triggers dialog - [when model changes cause view to update]).
Here's the 'local' iLogic rule code:
Sub Main
Dim oDDoc As DrawingDocument = ThisDoc.Document
Dim oSheet As Sheet = oDDoc.ActiveSheet
'delete all existing Centermarks
For Each oCM As Centermark In oSheet.Centermarks
oCM.Delete
Next
'create new Centermarks
UpdateCLSettings(oDDoc) 'uses below Sub to update centerline/centermark settings
Dim oCLs As ObjectsEnumerator
For Each oView As DrawingView In oSheet.DrawingViews
oCLs = oView.SetAutomatedCenterlineSettings(oACS)
Next
End Sub
Sub UpdateCLSettings(oDrawDoc As DrawingDocument)
'make sure your Automated Centerline (and Centermark) Settings are the way you want them
Dim oACS As AutomatedCenterlineSettings = oDrawDoc.DrawingSettings.AutomatedCenterlineSettings
oACS.ApplyToBends = False
oACS.ApplyToCircularPatterns = True
oACS.ApplyToCylinders = False
oACS.ApplyToFillets = False
oACS.ApplyToHoles = True
oACS.ApplyToPunches = True
oACS.ApplyToRectangularPatterns = True
oACS.ApplyToRevolutions = False
oACS.ApplyToSketches = False
oACS.ApplyToWorkFeatures = False
'oACS.ArcAngleThreshold =
'oACS.CircularEdgeMaximumThreshold =
'oACS.CircularEdgeMinimumThreshold =
'oACS.FilletRadiusMaximumThreshold =
'oACS.FilletRadiusMinimumThreshold =
oACS.ProjectionNormalAxis = True
oACS.ProjectionParallelAxis = True
'oACS.RadiusThresholdPrecision =
End Sub
If this solved your problem, or answered your question, please click ACCEPT SOLUTION.
Or, if this helped you, please click (LIKE or KUDOS) 👍.
If you want and have time, I would appreciate your Vote(s) for My IDEAS 💡or you can Explore My CONTRIBUTIONS
Wesley Crihfield
(Not an Autodesk Employee)
