10:07 PM
- Mute
- Permalink
- Report
Hi All,
I have this code to place the information text under the drawing view.
How do I center all the text in the label? When I run it it make is Left Centered and then need to manually change it to center justification.
Thank you very much for help 🙂
Dim oSSet As SelectSet = ThisDoc.Document.SelectSet If oSSet.count = 0 Then MessageBox.Show("You must select a drawing view first", "iLogic") Exit Sub End If 'Reference to the drawing view from the 1st selected object Dim oView As DrawingView = TryCast(oSSet.item(1), DrawingView) If oView IsNot Nothing Then oView.ShowLabel = True 'format the model iproperties oStockNumber = "<StyleOverride Underline='TRUE'>DETAIL ITEM <Property Document='model' PropertySet='Design Tracking Properties' Property='Stock Number' FormatID='{32853F0F-3444-11D1-9E93-0060B03C1CA6}' PropertyID='29'>STOCK NUMBER</Property></StyleOverride>" oDescription = "<Br/><StyleOverride Underline='False'> MATERIAL: <Property Document='model' PropertySet='Design Tracking Properties' Property='Description' FormatID='{32853F0F-3444-11D1-9E93-0060B03C1CA6}' PropertyID='29'>DESCRIPTION</Property></StyleOverride>" 'oPartNumber = "<StyleOverride Underline='True'> - MK <Property Document='model' PropertySet='Design Tracking Properties' Property='Part Number' FormatID='{32853F0F-3444-11D1-9E93-0060B03C1CA6}' PropertyID='5'>PART NUMBER</Property></StyleOverride>" 'oStringMass = "<Br/><StyleOverride Underline='False' FontSize='0.35'>EST UNIT MASS = <PhysicalProperty PhysicalPropertyID='72449' Precision='2'>MASS</PhysicalProperty></StyleOverride>" oStringScale = "<Br/><StyleOverride FontSize='0.35'>(<DrawingViewScale/>)</StyleOverride>" 'add to the view label oView.Label.FormattedText = oStockNumber & oDescription & oStringScale Else MessageBox.Show("The selected object is not a drawing view", "iLogic") End If
