I'm not sure what you want to center the view relative to. The center of the sheet or something else. Below is a simple VBA sample that demonstrates placing some view of a folded model and then places a view of the flat pattern. It first calculates the center of the border and uses that as the position, then it calculates a point at a slight offset from the upper-left corner of the border and moves it there. The position property of the drawing view is the center of the view so I'm also using the view width and height properties to get is positioned in the corner.
Public Sub AddAndPositionViews()
Dim drawDoc As DrawingDocument
Set drawDoc = ThisApplication.ActiveDocument
Dim sht As Sheet
Set sht = drawDoc.ActiveSheet
Dim tg As TransientGeometry
Set tg = ThisApplication.TransientGeometry
Dim filename As String
filename = "C:\Temp\PunchTest.ipt"
Dim sheetMetalDoc As PartDocument
Set sheetMetalDoc = ThisApplication.Documents.Open(filename, False)
Dim foldedFrontView As DrawingView
Dim pstn As Point2d
Set pstn = tg.CreatePoint2d(20, 10)
Set foldedFrontView = sht.DrawingViews.AddBaseView(sheetMetalDoc, pstn, 1, kFrontViewOrientation, kHiddenLineDrawingViewStyle)
Dim foldedRightView As DrawingView
Set pstn = tg.CreatePoint2d(40, 10)
Set foldedRightView = sht.DrawingViews.AddProjectedView(foldedFrontView, pstn, kHiddenLineDrawingViewStyle)
Dim isoView As DrawingView
Set pstn = tg.CreatePoint2d(40, 30)
Set isoView = sht.DrawingViews.AddProjectedView(foldedFrontView, pstn, kHiddenLineRemovedDrawingViewStyle)
Dim borderRange As Box2d
Set borderRange = sht.Border.RangeBox
Dim flatView As DrawingView
Set pstn = tg.CreatePoint2d((borderRange.MinPoint.x + borderRange.MaxPoint.x) / 2, (borderRange.MinPoint.y + borderRange.MaxPoint.y) / 2)
Dim options As NameValueMap
Set options = ThisApplication.TransientObjects.CreateNameValueMap
Call options.Add("SheetMetalFoldedModel", False)
Set flatView = sht.DrawingViews.AddBaseView(sheetMetalDoc, pstn, 1, kDefaultViewOrientation, kHiddenLineRemovedDrawingViewStyle, , , options)
flatView.DisplayBendExtents = True
MsgBox ("Center")
Dim newPosition As Point2d
Set newPosition = tg.CreatePoint2d(borderRange.MinPoint.x, borderRange.MaxPoint.y)
newPosition.x = newPosition.x + flatView.Width / 2 + 1
newPosition.y = newPosition.y - (flatView.Height / 2 + 1)
flatView.Position = newPosition
End Sub
