Catastrophic failure
System.Runtime.InteropServices.COMException was caught
  ErrorCode=-2147418113
  Message=Catastrophic failure (Exception from HRESULT: 0x8000FFFF (E_UNEXPECTED))
Any ideas why Running Inventor 2012 Apprentice, VB.Net 10, I get the above error with the basic setup as shown below?
I will go through a couple of files before it hits the catch and I think it always works on the first retry.
       oApprentice = New ApprenticeServerComponent
        Dim oDoc As ApprenticeServerDrawingDocument = Nothing
        Try
            Dim i As Integer = list.Count
            While System.Math.Max(System.Threading.Interlocked.Decrement(i), i + 1)
retry:
                Try
                    oDoc = oApprentice.Open(list(i))
                Catch ex As Exception
                    iTry = iTry + 1
                    If iTry <= 3 Then
                        GoTo ReTry
                    End If
                End Try
                iTry = 0
                oDoc.Close()
                oDoc = Nothing
                list.RemoveAt(i)
                UpdateList()
            End While
same error here, except i'm doing a totally different thing, i think it's because of multiple instances of inventor being launched ... or something that regards th translator plugins, in inventor 2013 i don't have this issue
adam.nagy
Autodesk Support
Autodesk Support
Hi Kent,
Are you running multiple instances of Inventor? Are you using multiple threads by any chance?
Any info you could provide about the context in which this code is running?
You could also rewrite the code to get rid of
I guess it was added by a code converter when you converted --i from C# to VB.NET?
You could use a For Each instead to iterate through the contents of the list.
Thank you,
Adam Nagy
Autodesk Platform Services
I'm launching multiple instances of inventor in separate task/thread using the TPL for each instance i get the translator addin and try to save them as a different format, seems that it has something to do with the document beying opened in non visible behaviour
xiaodong_liang
Autodesk Support
Autodesk Support
did you mean when you use Translator Addin with Inventor  = invisible, you got a problem? I do not hear a limitation for such scenario. Could you elaborate or share more information/dataset?
take a look at case num: 08044401 in adn
