Cannot export to dwg autocad drawing
Please I have problems with exporting a Inventor drawing to dwg autocad drawing, the message I get when a try is: Cannot open XML file: c:....Inventor 2014/InventorCustomization.xml.
xiaodong_liang
Autodesk Support
Autodesk Support
is this a problem you used any API code? or just a result of UI operation? If the formmer, could you provide the test code? If the latter, could you post the question to product board? http://forums.autodesk.com/t5/Inventor-General/bd-p/78
Today I have Inventor Professional 2015 and I still the problem to export a drawing to AutoCAD DWG files. The displayed message is only: "Problems encountered while saving the document.". This problem is just to exporting to autoCAD file, while exporting to Inventor files dwg there are no problems.
PD: I'm not using API code
Greetings
Yes, you are right. There is a problem with exporting. I remember when I installed 2014 and tried to export in AutoCAD dwg, Ihad got similar message. At this moment I don't remember solution, but I will try to find out. Did you instal AutoCAD with Inventor?
Nedeljko.
